BigNeilM
Pi Zer0 clock frequency
Mon Nov 30, 2015 9:13 am
The advertised clock frequency for Pi Zer0 is 1GHz, but the default setting determined through /boot/config.txt or raspi-config seems to be 700MHz, whatever the hardware.
I'm guessing the Pi Zer0 needs to be set to the higher clock speed and it's not automatic.
Is this correct or did I miss something?
Neil Matthews
Lost count how many of As, Bs, APluses, BPluses, Pi2s and now a couple of Zer0s. :-)
Get your E-paper HAT at www.percheron-electronics.uk/shop
Re: Pi Zer0 clock frequency
Mon Nov 30, 2015 9:17 am
BigNeilM wrote:The advertised clock frequency for Pi Zer0 is 1GHz, but the default setting determined through /boot/config.txt or raspi-config seems to be 700MHz, whatever the hardware.
Did you undertake a fresh install of Raspbian Wheezy ?
viewtopic.php?f=63&t=126849&start=200#p852351
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
BigNeilM
Mon Nov 30, 2015 9:42 am
No. I'm using the latest and greatest Raspbian Jessie.
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.1.13+ #826 PREEMPT Fri Nov 13 20:13:22 GMT 2015 armv6l GNU/Linux
Neil Matthews
