Pi Zero and HiPi module
Posted: Sun Nov 29, 2015 4:36 pm
by harwoodr
Hi all, has anyone managed to get pi zero running 'jessie' to install HiPi module?,, i keep getting dependancy issues and it states OpenGL not installed (but it is). if any one can help it would be really appeciated..
Re: Pi Zero and HiPi module
Posted: Wed Dec 02, 2015 12:12 pm
by RaTTuS
an you post a link to this HiPi ?
the only thing I can find is from 2013
Posted: Thu Dec 03, 2015 2:02 pm
by harwoodr
Posted: Thu Dec 03, 2015 2:19 pm
by fruitoftheloom
The link by the date is for Raspbian Wheezy, it should feasible to install Wheezy but will likely need to be updated on another RPi before RPi0 is supported
Natively OpenGL ES is supported..
Posted: Thu Dec 03, 2015 2:31 pm
by harwoodr
Thanks i will try that see if wheezy will boot at all
Posted: Thu Dec 03, 2015 3:47 pm
by DougieLawson
harwoodr wrote:Thanks i will try that see if wheezy will boot at all
If you build wheezy on another RPi then run sudo rpi-update it will boot OK on a Pi0.
Posted: Tue Mar 15, 2016 6:29 pm
by wallasey
I have released an updated version of the HiPi modules that support Pi 3, Pi 2, Pi Zero, Pi B+, Pi A+ Pi B and Pi A.
http://raspberry.znix.com/2016/03/hipi- ... eased.html
