LucaBuca
Playing 4k video in 1080p mode?
Sun Nov 29, 2015 2:30 pm
Is this possible?
I have a bunch of videos recorded on a phantom drone. They are in 4k, and when I try to play them on my TV using Kodi/Raspberry pie the TV turns off (no hdmi signal) because it doesn't support such a high resolution.
Is there a way to force a 4k video to play at a much lower resolution so that the TV doesn't think it's unplugged? Is there a way to force kodi to use a fixed resolution instead of the videos native resolution?
Thanks!
expandables
Re: Playing 4k video in 1080p mode?
Sun Nov 29, 2015 2:56 pm
The only way you can watch your videos on the raspberry pi is if you convert your 4k video to 1920x1080p.
The GPU of the PI can't handle 4k videos.
:twisted:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
neoaus
Mon Sep 19, 2016 7:36 pm
Is this still not possible with the Raspberry Pi3? I have many 4K videos. So converting them to 1080 would be a lot of work.
6by9
Mon Sep 19, 2016 9:15 pm
neoaus wrote:Is this still not possible with the Raspberry Pi3? I have many 4K videos. So converting them to 1080 would be a lot of work.
Not with hardware acceleration. All Pi's have the same GPU hardware.
You could software decode them (not in realtime) if that helps your use case.
