bmstrong
200gb MicroSD Card In The Pi's?
Sat Nov 28, 2015 4:48 pm
http://elinux.org/RPi_SD_cards
Has anyone tested the 200gb:
http://www.amazon.com/SanDisk-Ultra-200 ... ro+sd+card
In any of the Pi's? I picked one up for a Mobile phone, on sale this weekend, but thinking about it, the 200gb really could live on a Pi Zero with Kodi on my basement HDTV when I'm done using it in the cell. Plus, it's kind of insane/cool that the storage costs more than the machine itself. (Even that in itself is amazing for stuffing 200gb into something that small.)
Should I expect any problems? I've used a 128gb in other Pi's and experienced no problems.
ric96
Re: 200gb MicroSD Card In The Pi's?
Sat Nov 28, 2015 4:49 pm
can't see why not, but i would still suggest to store media on an external usb hdd.
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
gkreidl
Sat Nov 28, 2015 5:50 pm
For the same price I get 2 USB HDDs (or one very large one), which is much faster and more reliable than any SD card.
Minimal Kiosk Browser (kweb)
ajmas
Sat Nov 28, 2015 6:11 pm
Looks interesting. Would certainly eliminate the need for a USB hub to power an external hard-drive.
gkreidl
Sat Nov 28, 2015 6:23 pm
ajmas wrote:Looks interesting. Would certainly eliminate the need for a USB hub to power an external hard-drive.
You don't need a hub to power one HDD drive.
ajmas
Sat Nov 28, 2015 8:02 pm
I haven't had much luck with external 2.5" drives, without a powered hub. Are there any you can recommend that are low enough power usage to work?
kusti8
Sat Nov 28, 2015 8:21 pm
Did you add max_usb_current=1 to config.txt?
Speedwell68
Sat Nov 28, 2015 8:22 pm
What model RPI do you have.
This applies to RPi B+ & 2B with a decent quality 5V2A PSU
https://projects.drogon.net/testing-set ... berry-pi-b
The other models will require a decent quality Mains Powered USB2 Hub...
Thinking outside the box is better than burying your head in the sand...
ajmas
Mon Nov 30, 2015 3:44 pm
I have been using the Raspberry Pi B, though I have just got the Raspberry Pi 2 B, so I haven't seen if it makes much difference.
Mind you the 200GB module looks interesting and I would imagine that it would be supported by Linux, though like anything SD, probably best used for applications where writes aren't too high - I was reading that that things like dashcams can exhaust the write cycle of SD cards pretty fast.
Massi
Mon Nov 30, 2015 3:50 pm
ajmas wrote:I have been using the Raspberry Pi B, though I have just got the Raspberry Pi 2 B, so I haven't seen if it makes much difference.
Yes, it makes.
The power circuitry is completely different.
On my old B model, if i attach a external usb drive the raspi reboots.
On the new pi2 (but even a b+ is the same), the usb_max_current option allows to use external hdd with no problems
FREE WING
Tue Oct 24, 2017 1:53 am
I tested microSDXC 200GB UHS-I card - SanDisk Ultra Premium Edition SDSDQUAN-200G-G4A microSD with Raspberry Pi 3 .
It works fine .
http://www.neko.ne.jp/~freewing/raspber ... ard_200gb/
Imperf3kt
Tue Oct 24, 2017 2:41 am
It works fine .
And did it work fine two years ago on a Pi2B?
55:55:44:44:4C
52:4C:52:42:41
FREE WING
Tue Oct 24, 2017 3:13 am
I don't have Pi2B .
So I don't know it works fine or not with Pi2B .
texy
Tue Oct 24, 2017 10:20 am
I don't have Pi2B .
You replied to a thread over 2 years old when the Pi2B was the version in question.
Your reply to this post is therefore irrelevant. Probably best not to reply to threads like this unless you hardware is like-for-like ;)
Texy
FREE WING
Wed Oct 25, 2017 5:01 am
I don't have Pi2B .
Texy
OKay .
I got Pi2B and tested it .
It also works fine . ;-)
Just now become clearly that . 200GB SD card works fine with Pi2B .
i486
Wed Oct 25, 2017 7:37 am
In case of SD crash, it will be 200GB crash :)
