The gist of it:
- A+ idle - ~200 mA
- B+ idle - ~240 mA
- model 2 B idle - ~420 mA
- Zero idle - ~65 mA
[Update: s/mW/mA]
and how well does it play full HD video?solar3000 wrote:My arduino GEMMA2 uses 9mA on full blast.
My A+ and Zero idling measurements were exactly the same. 100 mA for both (@ 5.09V) I notice you used a very cheap USB charge doctor for your measurements. I wonder if it's a little "wonky" at the low end? I used a calibrated shunt.geerlingguy wrote:
- A+ idle - ~200 mW
- B+ idle - ~240 mW
- model 2 B idle - ~420 mW
- Zero idle - ~65 mW
echo 0 | sudo tee /sys/devices/platform/soc/20980000.usb/buspower >/dev/null
sleep 10
echo 1 | sudo tee /sys/devices/platform/soc/20980000.usb/buspower >/dev/null
And that's no random accident or unexpected eventdaveake wrote: I trust the Fluke above the USB tester.
At one frame every six minutes probably.rpdom wrote:and how well does it play full HD video?solar3000 wrote:My arduino GEMMA2 uses 9mA on full blast.
Thanks for posting your results (and to others too!); I did use a chintzy little USB 'Charger Doctor', and yes, it's highly likely to be inaccurate at very low readings (just like my Kill-a-Watt meter is highly unreliable below about 50W).mikerr wrote:I've not managed to go below 66ma
More usefully though I can get it down to 69ma with wifi dongle connected by sending usb to sleep for as long as needed.
You just needed to end with /ssolar3000 wrote:At one frame every six minutes probably.rpdom wrote:and how well does it play full HD video?solar3000 wrote:My arduino GEMMA2 uses 9mA on full blast.
I was messing with 'geerlingguy'
He was talking about low power. How about my digital watch. I haven't change the original battery for ten years. So how many pico amps would that be?
My measurements were taking headless with nothing plugged in, so that could definitely make the ranges a lot narrower; when I plug in HDMI, keyboard, wireless trackpad, and WiFi to the Zero, it jumps up to ~500-600 mA!alexeames wrote:My A+ and Zero idling measurements were exactly the same. 100 mA for both (@ 5.09V) I notice you used a very cheap USB charge doctor for your measurements. I wonder if it's a little "wonky" at the low end? I used a calibrated shunt.geerlingguy wrote:
- A+ idle - ~200 mA
- B+ idle - ~240 mA
(edit to add that my measurements were all taken with USB keyboard/mouse dongle and HDMI attached and in use)
geerlingguy wrote:mikerr wrote:I've not managed to go below 66ma
... still nothing near Fluke-grade
I just need to bite the bullet and get one... as a Christmas gift to myselfdaveake wrote:geerlingguy wrote:mikerr wrote:I've not managed to go below 66ma
... still nothing near Fluke-grade. Any cheap DMM will be an order of magnitude more accurate and precise than the USB tester; you just need to get it inline between power source and Pi. I only mention the Fluke because, after 30 years of cheaper meters, I finally bought one last month
That depends on which battery it takes. Mine uses a CR1620 cell, which has a capacity of around 75mAh. If it lasts 10 years then the average discharge rate would be 0.075(Amps) / 87660(hours) or 0.000000856A which is 0.000856 mA, 0.856 uA, 856 nA or 856000 pico Amps. (If I got my maths anywhere near right)solar3000 wrote:At one frame every six minutes probably.rpdom wrote:and how well does it play full HD video?solar3000 wrote:My arduino GEMMA2 uses 9mA on full blast.
So if I read your pictures right Trevor, there was ~30mA range between the three when measuring ~200mA?FTrevorGowen wrote:[Slightly O.T.] W.r.t. to "Charger Doctor" current measurements - FWIW I measured the behaviour of three samples cf. an Adafruit current meter over a nominal current range of 9 to 750 mA when the devices first became available. The details are within my webpages here:
http://www.cpmspectrepi.webspace.virgin ... octor.html
Trev.
That's not quite the "whole story". Having observed that the C.D.'s were more linear than the (Hall effect based?) Adafruit meter I was checking for variations in the linear slope and offsets. Given that the device's "quantization error" is ~10mA (cf. ~10mV/Rload for the DMM used to measure the voltage across the resistive loads use to determine the "reference currents", Ise3) two of the devices exhibited an offset consistent with that error margin (-10 and +11 mA). The other device's offset was much greater, ie. +38mA. Ironically that device's slope was somewhat closer to 1.0 (0.96 cf. 0.94). However, compared to the Adafruit current meter's values of -120mA and 1.55, the C.D.'s values were all significantly "better".alexeames wrote:So if I read your pictures right Trevor, there was ~30mA range between the three when measuring ~200mA?FTrevorGowen wrote:[Slightly O.T.] W.r.t. to "Charger Doctor" current measurements - FWIW I measured the behaviour of three samples cf. an Adafruit current meter over a nominal current range of 9 to 750 mA when the devices first became available. The details are within my webpages here:
Trev.
its a casio databank/calculator. I don't remember if I ever opened it.rpdom wrote: ...........
I expect my watch uses more power than yours. I bought it in 2005 and I've had to change the battery a couple of times (ok, the last one was a cheap battery and only lasted a couple of years). The radio time receiver on it probably uses a fair bit of power. That runs three or four times every morning for around 5-10 minutes.solar3000 wrote:its a casio databank/calculator. I don't remember if I ever opened it.rpdom wrote: ...........
which battery it takes. Mine uses a CR1620 cell, which has a capacity of around 75mAh. If it lasts 10 years then the average discharge rate would be 0.075(Amps) / 87660(hours) = 856000 pico Amps. (If I got my maths anywhere near right)
Can't be. Its got to be less than that. At full charge it is over 3V. So the watch should start complaining at below 2V. So it probably uses a few micro amps. I mean after more than ten years.
I just checked. I purchased the watch Oct 2003. So that's 12 years. The backlight still shines. So it should still be just below 3V.
Its got to be above 1/2 or 3/4 capacity.
