grit
GPIO to GPIO on same pi?
Thu Nov 19, 2015 3:21 pm
Hi All,
I have a question, I'm about to connect two GPIO pins to each other with resistor/led in between like so:
GPIO23 ----[220]--->|-----GPIO27
I wanted to set GPIO27 on pulldown low,low and control the LED with the GPIO23 signal. Question is... is this a 'legal' solution?
Thanks!
Re: GPIO to GPIO on same pi?
Thu Nov 19, 2015 3:30 pm
Yes. It's common to do that for "charlieplexing". Source on one GPIO, sink on another. With two LEDs wired anode to cathode you can light one by setting pin#1 high/pin#2 low and the other by setting pin#1 low/pin#2 high. Both pins high or both pins low means the LEDs are both off.
grit
Thu Nov 19, 2015 3:40 pm
Thanks Doug!
