pavithan
Type Error: Float is required
Thu Nov 12, 2015 5:34 am
I have some issues on float conversion: Here is my code and Error message, need urgent help
Error Message
File "stepper_sensor.py", line 146, in <module>
forward(float(delay) / 1000.0, int(steps))
File "stepper_sensor.py", line 104, in forward
r, theta, z = mapping(lDistances,angle, z1)
File "stepper_sensor.py", line 121, in mapping
r= float(lDistances*math.sin(angle))
TypeError: a float is required
import RPi.GPIO as GPIO
import time
import os
import fileinput
import plotly.plotly as py
from plotly.graph_objs import *
import math
import array
username = 'pavi'
api_key = 'oegyhub3vl'
stream_token = '2idjptldya'
py.sign_in(username, api_key)
GPIO.setmode(GPIO.BCM)
enable_pin = 18
coil_A_1_pin = 4
coil_A_2_pin = 2
coil_B_1_pin = 24
coil_B_2_pin = 25
GPIO_TRIGGER = 15
GPIO_ECHO = 14
GPIO.setup(enable_pin, GPIO.OUT)
GPIO.setup(coil_A_1_pin, GPIO.OUT)
GPIO.setup(coil_A_2_pin, GPIO.OUT)
GPIO.setup(coil_B_1_pin, GPIO.OUT)
GPIO.setup(coil_B_2_pin, GPIO.OUT)
print "Ultrasonic Measurement"
# Set pins as output and input
GPIO.setup(GPIO_TRIGGER,GPIO.OUT) # Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN) # Echo
# Set trigger to False (Low)
GPIO.output(GPIO_TRIGGER, False)
GPIO.output(enable_pin, 1)
def forward(delay, steps):
angle = []
#Create a list to store distances
lDistances = []
z1 = []
for i in range(1, steps):
degree= i/1.422
# print '{:1.1f}'.format(degree)
setStep(1, 0, 1, 0)
time.sleep(delay)
setStep(0, 1, 1, 0)
time.sleep(delay)
setStep(0, 1, 0, 1)
time.sleep(delay)
setStep(1, 0, 0, 1)
time.sleep(delay)
angle.append(degree)
with open('angle.txt','a') as file:
for item in angle:
file.write("{:1.1f}\n".format(item))
time.sleep(0.3)
# Send 10us pulse to trigger
GPIO.output(GPIO_TRIGGER, True)
time.sleep(0.00001)
start = time.time()
while GPIO.input(GPIO_ECHO)==0:
start = time.time()
while GPIO.input(GPIO_ECHO)==1:
stop = time.time()
# Calculate pulse length
elapsed = stop-start
# Distance pulse travelled in that time is time
# multiplied by the speed of sound (cm/s)
distance = elapsed * 34300
# That was the distance there and back so halve the value
distance = distance / 2
print "Distance : %.1f" % distance+ " " + '{:1.1f}'.format(degree)+ " "+ '{:1.1f}'.format(count1)
if i > 0 and distance > 0:
lDistances.append(distance)
with open('distances.txt','a') as file:
for item in lDistances:
z1.append(count1)
with open('z1.txt','a') as file:
for item in z1:
trace0 = Scatter3d(x= r, y= theta, z=z1)
layout = Layout(
title='Raspberry Pi Streaming Sensor Data'
fig = Figure(data=[trace0], layout=layout)
plot_url = py.plot(fig)
def mapping(lDistances,angle, z1):
theta = distance*math.cos(angle)
z = float(count1)
return r, theta, z
def setStep(w1, w2, w3, w4):
GPIO.output(coil_A_1_pin, w1)
GPIO.output(coil_A_2_pin, w2)
GPIO.output(coil_B_1_pin, w3)
GPIO.output(coil_B_2_pin, w4)
count1 = 0
while True:
r = raw_input("do you want to run (y/n): ")
count1 += 1
count = 0
while (count <1):
if r == 'y':
delay = 10.0
steps = 512.0
count = count + 1
# Reset GPIO settings
GPIO.cleanup()
PeterO
Re: Type Error: Float is required
Thu Nov 12, 2015 10:04 am
import time
import os
import fileinput
import math
import array
username = 'pavi'
enable_pin = 18
coil_A_1_pin = 4
coil_A_2_pin = 2
coil_B_1_pin = 24
coil_B_2_pin = 25
GPIO_TRIGGER = 15
GPIO_ECHO    = 14
  angle = []
  lDistances = []
  z1 = []
      degree= i/1.422
      setStep(1, 0, 1, 0)
      time.sleep(delay)
      setStep(0, 1, 1, 0)
      time.sleep(delay)
      setStep(0, 1, 0, 1)
      time.sleep(delay)
      setStep(1, 0, 0, 1)
      time.sleep(delay)
	  for item in angle:
      time.sleep(0.3)
      time.sleep(0.00001)
      start = time.time()
          start = time.time()
          stop = time.time()
      z1.append(count1)
        for item in z1:
  layout = Layout(
  [b]r= float(lDistances*math.sin(angle))
  theta = distance*math.cos(angle)[/b]
  z = float(count1)
  return r, theta, z
count1 = 0
while True:
	count1 += 1
	count = 0
	while (count <1):
	    if r == 'y':
	        delay = 10.0
	        steps = 512.0
	        count = count + 1
GPIO.cleanup()
PeterO
Thu Nov 12, 2015 10:10 am
At first I thought the problem was that you are trying to convert a list into a float (which wouldn't work).
But on further looking I thing the problem is that you are trying to take the sine of a list.
I **THINK** you need some list comprehension in there to go through all the elements of the lists in turn and compute the sine and do the multiplication.
BUT list comprehensions are something that I'm not very good at so I'll wait for a better Python progrrammer to come along :-)
PeterO
Aydan
Thu Nov 12, 2015 10:29 am
List comprehension works like this:
e.g. calculate sines for a list of floats:
#this returns a list of the results:
result=[math.sin(x) for x in list_of_floats]
#this returns a generator object to be iterated over:
result=(math.sin(x) for x in list_of_floats)
or:
result=map(math.sin,list_of_floats)
# calls function math.sin for each element of list_of_floats
Reagrds
Aydan
pavithan
Fri Nov 13, 2015 4:42 am
Aydan wrote:List comprehension works like this:
or:
Reagrds
Aydan
this what i tired but still have some error
r= lDistances*[math.sin(angle)for angle in list_of_floats]
theta = lDistances*[math.cos(angle)for angle in list_of_floats]
z = (count1)
return r, theta, z
ERROR MSG
float(forward(float(delay) / 1000.0))
NameError: global name 'list_of_floats' is not defined
AndyD
Fri Nov 13, 2015 5:06 am
pavithan wrote:this what i tired but still have some error
z = (count1)
return r, theta, z
ERROR MSG
I think you want:-
r = [distance * math.sin(angle) for distance in lDistances]
theta = [distance * math.cos(angle) for distance in lDistances]
Aydan
Fri Nov 13, 2015 10:00 am
z = (count1)
return r, theta, z
ERROR MSG
I think you want:-
AndyD is correct.
pavithan: I only gave you an example. You have to adapt it to you code. list_of_floats was only a placeholder for your actual list of floats.
Regards
Aydan
