piktostest
apt-get install sqlite3 problem
Sat Nov 07, 2015 1:46 pm
I'm tring to install sqlite but there is a problem.
Please help
sudo apt-get install sqlite3
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 sqlite3 : Depends: libsqlite3-0 (= 3.7.13-1+deb7u2) but 3.8.7.1-1+deb8u1 is to be installed
E: Unable to correct problems, you have held broken packages.
sudo apt-cache policy sqlite3
sqlite3:
  Installed: (none)
  Candidate: 3.7.13-1+deb7u2
  Version table:
     3.7.13-1+deb7u2 0
        500 http://mirrordirector.raspbian.org/raspbian/ wheezy/main armhf Packages
My sources.list file
# Original mirror
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
piktostest
Re: apt-get install sqlite3 problem
Sat Nov 07, 2015 7:34 pm
Please tell me, have you got the same problem as me , during installation SQLite ? Could You try it ?
stderr
Sat Nov 07, 2015 10:06 pm
piktostest wrote:Please tell me, have you got the same problem as me , during installation SQLite ? Could You try it ?
Installed without complaint on Wheezy original RPi for me.
Sun Nov 08, 2015 9:58 am
If you say that you should explain how your system is different to the OP's system so he/she can make the changes needed to fix his. Just saying "I've got one here that works." is useless.
Both you and the OP need to look at /etc/apt/sources.list and the files in /etc/apt/sources.list.d and compare them. Because otherwise I'm going to have to build a Wheezy system to discover what's wrong with the OP's system.
stderr
Sun Nov 08, 2015 4:25 pm
DougieLawson wrote:If you say that you should explain how your system is different to the OP's system so he/she can make the changes needed to fix his. Just saying "I've got one here that works." is useless.
I don't have access to his system. He said, "Could you try it?" I tried it and it installed as far as I could tell without complaint. There's nothing special about my configuration that I know of so there wasn't much more I could say.
My sources.list says: deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi . The sources.list.d dir has a file called raspi.list which has deb http://archive.raspberrypi.org/debian/ wheezy main in it. I'm pretty sure that sqlite3 is in the standard repositories so an install attempt should just work.
Sun Nov 08, 2015 5:46 pm
The sources.list file isn't the only file that has entries for repositories. There are also files in /etc/apt/sources.list.d/ as well.
What may be helpful is if you and the OP both post the output of the "apt-cache policy" command (sudo not required) on your respective machines and compare the results.
piktostest
Mon Nov 09, 2015 6:20 am
Maybe I have wrong entries in sources.list / raspi.list files ? or maybe there is a problem in repository ?
sources.list
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
raspi.list
deb http://archive.raspberrypi.org/debian/ jessie main ui
deb-src http://archive.raspberrypi.org/debian/ jessie main ui
apt-cache policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://archive.raspberrypi.org/debian/ jessie/ui armhf Packages
release o=Raspberry Pi Foundation,a=stable,n=jessie,l=Raspberry Pi Foundation,c=ui
origin archive.raspberrypi.org
500 http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
release o=Raspberry Pi Foundation,a=stable,n=jessie,l=Raspberry Pi Foundation,c=main
500 http://mirrordirector.raspbian.org/raspbian/ wheezy/rpi armhf Packages
release v=7.0,o=Raspbian,a=oldstable,n=wheezy,l=Raspbian,c=rpi
origin mirrordirector.raspbian.org
500 http://mirrordirector.raspbian.org/raspbian/ wheezy/non-free armhf Packages
release v=7.0,o=Raspbian,a=oldstable,n=wheezy,l=Raspbian,c=non-free
500 http://mirrordirector.raspbian.org/raspbian/ wheezy/contrib armhf Packages
release v=7.0,o=Raspbian,a=oldstable,n=wheezy,l=Raspbian,c=contrib
release v=7.0,o=Raspbian,a=oldstable,n=wheezy,l=Raspbian,c=main
Pinned packages:
Mon Nov 09, 2015 11:57 am
You have an odd mix of wheezy and jessie sources there, although I don't think that is causing the issue.
apt seems to be picking up the sqlite3 version from wheezy, but then finding the libsqlite3-0 from jessie, which doesn't match.
Perhaps you had jessie configured at one time and changed it back to wheezy?
Did you run "sudo apt-get update" before trying the install?
Could you run "apt-cache policy sqlite3 libsqlite3-0" to see where it is getting those versions from. This is what it shows on one of my jessie systems.
rpdom@raspi4:~$ apt-cache policy sqlite3 libsqlite3-0
sqlite3:
  Installed: (none)
  Candidate: 3.8.7.1-1+deb8u1
  Version table:
     3.8.7.1-1+deb8u1 0
        500 http://mirrordirector.raspbian.org/raspbian/ jessie/main armhf Packages
libsqlite3-0:
  Installed: 3.8.7.1-1+deb8u1
  Version table:
 *** 3.8.7.1-1+deb8u1 0
Mon Nov 09, 2015 12:33 pm
Rather then trying to patch up various incompatibilities, maybe it would be easier to start with a fresh install of Raspbian Jessie ;)
RPi 4B 4GB (SSD Boot)..
piktostest
Mon Nov 09, 2015 3:19 pm
Of Course, i use sudo apt-get update every time and even reboot device.
sudo apt-cache policy sqlite3 libsqlite3-0
sqlite3:
Installed: (none)
Version table:
3.7.13-1+deb7u2 0
libsqlite3-0:
Version table:
3.7.13-1+deb7u2 0
Mon Nov 09, 2015 3:24 pm
As I suspected, you have at least partially done an upgrade to jessie at some point, and the jessie version of libsqlite3-0 (3.8.7.1-1+deb8u1) is already installed.
Your options are:
a) force a downgrade of libsqlite3-0 to the wheezy version (3.7.13-1+deb7u2), which could be messy and will probably break your system.
b) change to the sources.list entries to jessie and upgrade various bits. This may break your system (it works for me because of how I've got my systems set up).
or c) reinstall either wheezy, or jessie from scratch as fruity suggested. This is the safest option.
piktostest
Mon Nov 09, 2015 3:45 pm
Thank you very much for all help. It's finally working.
