maihoaomv
apt-get update
Fri Nov 06, 2015 3:40 am
is there a problem with the repository or mirrordirector? i keep getting an error when i try to update jessie on the rpi for the last day or so.
pi@raspberrypi:~$ sudo apt-get update
Get:1 http://archive.raspberrypi.org jessie InRelease [13.3 kB]
Get:2 http://archive.raspberrypi.org jessie/main Sources [26.2 kB]
Hit http://archive.raspberrypi.org jessie/ui Sources
Get:3 http://archive.raspberrypi.org jessie/main armhf Packages [67.4 kB]
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_US
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
Fetched 107 kB in 2min 0s (887 B/s)
Reading package lists... Error!
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
pi@raspberrypi:~$
Gaeel
Re: apt-get update
Fri Nov 06, 2015 7:15 am
I'm getting the same problem, how do I set up mirrors?
Re: apt-get update
Fri Nov 06, 2015 9:07 am
Gaeel wrote:I'm getting the same problem, how do I set up mirrors?
All seems to be working this UK morning, so try again ;)
Take what I advise as advice not the utopian holy grail, and it is gratis !!
ethanol100
Re: apt-get update
Fri Nov 06, 2015 10:29 am
Try
sudo apt-get update -o Acquire::ForceIPv4=true
to force the use of IPv4 addresses. I suspect you can not route IPv6. If this update is successful, than you can create a file "/etc/apt/apt.conf.d/99force-ipv4" with the content:
Acquire::ForceIPv4 "true";
