VecH
[SOLVED] Raspbian Jessie, how check watchdog ?
Thu Nov 05, 2015 8:05 pm
How check watchdog timer onboard Raspberry PI
fork bomb
#/bin/python
#fork_bomb.py
import os
while True:
      os.fork()
not working, Raspberry PI freezes and not rebooted
this scrypt worked on Raspbian Wheezy
VecH
Re: Raspbian Jessie, how check watchdog ?
Fri Nov 13, 2015 3:38 am
Please check this forkbomb on Raspbian Jessie with Onboard watchdog
Aydan
Fri Nov 13, 2015 10:21 am
Do you actually have the watchdog enabled? By default it is not enabled.
VecH
Fri Nov 13, 2015 10:45 am
$ sudo modprobe bcm2708_wdog
$ sudo sh -c "echo 'bcm2708_wdog' >> /etc/modules"
$ sudo apt-get install watchdog chkconfig
$ sudo chkconfig watchdog on
$ sudo service watchdog start
Uncomment two string in file: /etc/watchdog.conf
$ sudo nano /etc/watchdog.conf
watchdog-device = /dev/watchdog
max-load-1 = 24
echo "options bcm2708_wdog nowayout=1 heartbeat=13" | sudo tee /etc/modprobe.d/watchdog.conf
$ sudo reboot
$ dmesg | grep watchdog
[   16.012628] bcm2708 watchdog, heartbeat=13 sec (nowayout=1)
Fri Nov 13, 2015 11:44 am
You need to edit /etc/modules and add
bcm2708_wdog
to get the kernel module loaded.
VecH
Fri Nov 13, 2015 11:48 am
I forget write in start
Post edited
Fri Nov 13, 2015 12:22 pm
I've tested this on both my A+ and my 2B and your fork bomb caused both systems to reboot.
That's with current Jessie and the leading edge 4.1.12+/4.1.12-v7+ #825 kernel (installed with rpi-update).
VecH
Fri Nov 13, 2015 2:09 pm
You use clear Raspbian Jessie or update from Wheezy ?
If clear install, start script in Jessie not started in boot and config watchdog module in file /etc/default/watchdog
service watchdog does not start when boot
If you manually run all started
How to diagnose?
p.s. I hate systemd
