how to minimise RPi2b power-consumption ?
Posted: Mon Nov 02, 2015 1:29 am
I have not used Rpi, but am considering a Pi 2B for 2 scenarios: general use requiring max power, b) unattended, headless data-logger in IoT environment, where previously SoC like the low-power Seeduino Stalker would be used (in sleep/wakeup mode) to log data - typically true 240V AC energy monitoring.
My questions are:
a) is it possible to run most of the supported OS's for RPi2b, with 3 cores shutdown, and if so, what is the power-consumption (assuming neglible port load)
b) apart from disabling HDMI, is there power-control for shutting down other unused onboard peripherals, eg USB ports
c) for scenario b, is it worth picking a different 240V PSU than the standard PSU used for scenario a
d) for scenario b, what is the power consumption from the wall, using the standard PSU ?
e) for scenario b, is there a standard Li-Ion battery backup solution to cover short-term 240VAC loss ?
My questions are:
