demsley
40 pin breakout
Thu Oct 29, 2015 4:01 pm
This may appear to be a silly question but can I open up the "blind" hole on an IDE cable and use it as a GPIO extender for the Raspberry Pi?
It is, after all, 40 pins as well.
Cheers
Dave :?:
All thoughts and comments are my own......
.... of course they are; who else would think like this?
Re: 40 pin breakout
Thu Oct 29, 2015 4:06 pm
As long as the cable is straight through and doesn't have any pins crossed over you should be OK.
Pin#20 (if I've counted it right) that's blocked is only a GND pin.
This is a doctor free zone.
Re: 40 pin breakout
Thu Oct 29, 2015 7:10 pm
Yes, if it an old-style 40-wire cable. "Newer" IDE/PATA cables used 80-wires to the 40 pin connectors and some of the pins are joined together which can be bad news for a Pi.
I can recognise the two types of cable just by looking at them, but if you aren't sure then just count the first ten wires - if that gets you about a quarter of the way across the cable then it is good. If not, don't use it.
JimmyN
Re: 40 pin breakout
Fri Oct 30, 2015 5:59 pm
Yes, I've done it to utilize some old IDE cables. It's just a thin layer of plastic over the hole, and the female connector is in there. But as mentioned it has to be a 40 conductor cable, not a 80 conductor.
