sim_tcr
[SOLVED] custom rc script not being called while shutdown.
Sun Oct 25, 2015 11:31 am
I am trying to make an rc script to shutdown our app (splunk) while system is rebooting. Below is the content of my rc script at /etc/init.d/rcsplunk
#!/bin/sh
# /etc/init.d/rcsplunk
# Subsystem file for "Splunk" server
# chkconfig: 23456 95 05
# description: Splunk server daemon
# processname: Splunk
# config: /etc/MySystem/mySystem.conf
# config: /etc/sysconfig/mySystem
# pidfile: /var/run/MySystem.pid
# source function library
. /etc/rc.d/init.d/functions
start() {
/apps/splunk/bin/splunk start
stop() {
/apps/splunk/bin/splunk stop
restart() {
/apps/splunk/bin/splunk restart
status() {
/apps/splunk/bin/splunk status
case "$1" in
        start)
                start
        stop)
                stop
        restart)
                stop
                start
        reload)
                reload
        condrestart)
                if [ -f /var/lock/subsys/$prog ] ; then
                        stop
                        # avoid race
                        sleep 3
                        start
                fi
        status)
                status $prog
                RETVAL=$?
                echo $"Usage: $0 {start|stop|restart|reload|condrestart|status}"
                RETVAL=1
esac
exit $RETVAL
I ran sudo chkconfig --add rcsplunk and sudo chkconfig rcsplunk on and below is the out put of chkconfig --list | grep rcsplunk
rcsplunk        0:off   1:off   2:on    3:on    4:on    5:on    6:on
Now my app splunk is not being shutdown when I run sudo reboot or sudo init 6 any help is appreciated.
Note: I noticed that app is being started when system come back up. Which i don't want to.
http://raspisimon.no-ip.org
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
sim_tcr
[SOLVED] Re: custom rc script not being called while shutdow
Mon Oct 26, 2015 4:02 pm
stop singal will get initiated only if there is a file in /var/lock/subsys/<rcscriptname>
So i put a touch stalemate as part of start section.
start() {
touch /var/lock/subsys/rcsplunk
and everything worked as expected.
