VecH
pigpiod + wiegand = incorrect read
Sat Oct 24, 2015 2:34 pm
I have the keys wiegand with number (read and verify in other devices) and these numbers are written on the keys themselves:
0009030510
0009487621
0009236067
0009328295
I am git clone pigpiod library, maked and installed
I use modified example: /pigpio/EXAMPLES/Python/WIEGAND_CODE/wiegand.py
   def callback(bits, value):
      print("bits={} value={}".format(bits, value))
to
      print(int(bin(value)[3:27],2))
for remove CRC bits and convert to integer and print
Only first key 0009030510 correct read and print
bits=26 value=51615453
9030510
other keys returns an incorrect value
0009487621 return 2198027
0009236067 return 1694918
0009328295 return 1879374
I tried to understand what the problem is, not work
translation into binary values, is evident that they are shifted
0009030510=9030510
100010011100101101101110
0009487621=2198027
100100001100010100000101
   1000011000101000001011
0009236067=1694918
100011001110111001100011
    110011101110011000110
0009328295=1879374
100011100101011010100111
    111001010110101001110
p.s. I can get values in bits for keys Wiegand with CRC or without
