sleathy03
Vncserver on Boot
Thu Oct 22, 2015 1:09 pm
How do you set a vncserver to come on when you boot up the raspberry pi. I am trying to run my pi via my laptop. I have installed it but I have to connect my pi to a monitor to turn on the vncserver and then connect using the Ethernet cable, to run the vncserver off the pi to the laptop. Is there a way to have it so when you turn the pi on it automatically starts running the vncserver so I can just connect it straight away to the pi. :?: :?:
Please help me with this one.
JRV
Re: Vncserver on Boot
Thu Oct 22, 2015 2:04 pm
I use this script to start a VNC session. VNC is not started until it is needed.
#!/bin/sh
ssh -X -4 [USER_NAME]@[CLIENT_IP_ADDRESS] tightvncserver -geometry 1440x900
vncviewer [RPi_IP_ADDRESS]
xanthor
Thu Oct 22, 2015 2:40 pm
For Raspbian Jessie (with systemd), you can create a service:
viewtopic.php?f=66&t=123457
Also remember that SSH is enabled by default.
sleathy03
Thu Oct 22, 2015 3:37 pm
JRV wrote:I use this script to start a VNC session. VNC is not started until it is needed.
#!/bin/sh
So do I just have to type it once, because I am trying to get it so I don't have to connect to a monitor to start the vncserver every time. Also I am quite a beginner so where do I type it. :D
JRV
Fri Oct 23, 2015 3:47 pm
Open your text editor on the client machine.
Copy that text into a text file.
Name it something easy to remember.
Open a terminal and make it executable with the command
chmod +x [FILENAME]
and run it with the command
./[FILENAME]
sleathy03
Fri Oct 23, 2015 6:50 pm
Ok Thank you so much.
stderr
Fri Oct 23, 2015 7:20 pm
[quote="sleathy03] [/quote]
The first line is supposed to start the server and the second is supposed to connect to it. Does that actually work with the default configuration? Maybe it does but there are permissions that need to be right in X which are there to prevent people getting into your system.
If you just want to run X apps off the RPi, you can also run ssh -X [email protected] program with the program you want, which is what the command line does in the example with vncserver. The application will just pop up on your local screen like a normal X program, assuming you are running X locally. Under Windows, perhaps try MobaXTerm or something like that. Lately I've been using X2Go in place of VNC, so look into other options.
