drekthrall
webiopi import error
Mon Oct 19, 2015 6:06 pm
I am using Webiopi ...
I wrote python script that controls GPIO ...
I have imported webiopi like that : import webiopi ...
In next line is that : GPIO = webiopi.GPIO
and rest of my script ...
When I want to run my script I am getting AttributeError: 'module' object has no attribute 'GPIO'
Please can anyone help me ? Thank you !
DirkS
Re: webiopi import error
Mon Oct 19, 2015 7:07 pm
drekthrall wrote:In next line is that : GPIO = webiopi.GPIO
See http://webiopi.trouch.com/PYTHONCLIENT.html.
Are you confusing webiopi with RPi.GPIO?
drekthrall
Mon Oct 19, 2015 7:29 pm
I think no.
This is python script what i want to run :
import webiopi
GPIO = webiopi.GPIO
# initiales setzen der Beschleunigung
acceleration = 0
# auf der Stelle drehen = false
spotturn = "false"
motorpwm2_in1_pin = 17
GPIO.setFunction(motorpwm1_in1_pin, GPIO.PWM)
GPIO.setFunction(motorpwm2_in1_pin, GPIO.PWM)
def initiate():
	global spotturn
	global acceleration
	global motorLspeed
	global motorRspeed
	global speedstep
	spotturn = "false"
	acceleration = 0
	motorLspeed = 0
	motorRspeed = 0
	speedstep = 5
# Mit den Funktionen reverse() und forward() wird festgelegt in
# welche Richtung sich die Motoren drehen sollen.
def reverse():
    GPIO.digitalWrite(motor1_in1_pin, GPIO.HIGH)
    GPIO.digitalWrite(motor1_in2_pin, GPIO.LOW)
    GPIO.digitalWrite(motor2_in1_pin, GPIO.LOW)
    GPIO.digitalWrite(motor2_in2_pin, GPIO.HIGH)
def  forward():
    GPIO.digitalWrite(motor1_in1_pin, GPIO.LOW)
    GPIO.digitalWrite(motor1_in2_pin, GPIO.HIGH)
    GPIO.digitalWrite(motor2_in1_pin, GPIO.HIGH)
    GPIO.digitalWrite(motor2_in2_pin, GPIO.LOW)
# Die Funktion stop() setzt den Motortreiber fuer die linke
# und rechte Seite auf False und stopt somit die Motoren.
# Weiter werden auch die Varialben fuer die Geschwindigkeit
# auf 0 zurueck gesetzt.
def stop():
	initiate()
	return 0, 0, 0
# Die Funktion setacceleration(... ) setzt die Geschwindigkeit der Motoren
def setacceleration(value):
	global motorLspeed
	global motorRspeed
	global acceleration
	global minspeed
	global maxspeed
	acceleration = acceleration + value
	minspeed, maxspeed = getMinMaxSpeed()
# Hier werden die min und max Werte der Geschwindigkeit ueberprueft
	if(acceleration < -40):
		acceleration = -40
	if(acceleration > 40):
		acceleration = 40
	if(acceleration > 0):
		# Vorwaertsfahrt
		forward()
		motorLspeed = acceleration
		motorRspeed = acceleration
	elif(acceleration == 0):
		# stoppen der Motoren
		motorLspeed, motorRspeed, acceleration = stop()
	else:
		# Rueckwaertsfahrt
		reverse()
		motorLspeed = (acceleration * -1)
		motorRspeed = (acceleration * -1)
	motorLspeed, motorRspeed = check_motorpseed(motorLspeed, motorRspeed)
# Diese Funktion dient der Ueberpruefung der Motorgeschwindigkeiten links und rechts
def check_motorpseed(motorLspeed, motorRspeed):
	if (motorLspeed < minspeed):
		motorLspeed = minspeed
	if (motorLspeed > maxspeed):
		motorLspeed = maxspeed
	if (motorRspeed < minspeed):
		motorRspeed = minspeed
	if (motorRspeed > maxspeed):
		motorRspeed = maxspeed
	return motorLspeed, motorRspeed
# Hier werden die Werte fuer die maximale und minimale Geschwindigkeit gesetzt
def getMinMaxSpeed():
	minspeed = 0
	maxspeed = 40
	return minspeed, maxspeed
# Diese Funktion liefert die Motorengeschwindigkeit zurueck
def getMotorSpeed():
	global motorLspeed
	global motorRspeed
# Diese Funktion liefert die Schrittweite fuer die Beschleunigung
def getMotorSpeedStep():
	return 5
# Ab hier werden fuer die Web-Oberflaeche / das Web-Interface die Knoepfe definiert.
# ButtonForward ist der Pfeil fuer die Vorwaertsfahrt
@webiopi.macro
def ButtonForward():
	fowardAcc = 0
	fowardAcc = getMotorSpeedStep()
	setacceleration(fowardAcc)
	motorLspeed, motorRspeed = getMotorSpeed()
	# Hier findet die Umrechnung in Prozentwerte statt fuer das PWM Signal
	valueL = float(motorLspeed)/100
	valueR =  float(motorRspeed)/100
	GPIO.pulseRatio(motorpwm1_in1_pin, valueL)
	GPIO.pulseRatio(motorpwm2_in1_pin, valueL)
# ButtonReverse ist der Pfeil fuer die Rueckwaertsfahrt
@webiopi.macro
def ButtonReverse():
	backwardAcc = 0
	backwardAcc = getMotorSpeedStep()
	setacceleration((backwardAcc*-1))
	GPIO.pulseRatio(motorpwm2_in1_pin, valueR)
# ButtonTurnLeft ist der Pfeil fuer die Linksfahrt
@webiopi.macro
def ButtonTurnLeft():
	global motorLspeed
	global motorRspeed
	global acceleration
	global speedstep
	global spotturn
# Wenn spotturn den Wert "left" hat und die Geradeausfahrt acceleration = 0 dann
# ist ein Drehen auf der Stelle moeglich.
	if(spotturn == "right" and acceleration == 0):
		spotturn = "left"
	if(motorRspeed < motorLspeed):
		motorRspeed = motorRspeed + speedstep
		motorLspeed = motorLspeed + speedstep
	else:
		motorLspeed = motorLspeed - speedstep
	valueL = valueL/100
	valueR = valueR/100
# ButtonTurnLeft ist der Pfeil fuer die Rechtsfahrt
@webiopi.macro
def ButtonTurnRight():
	global motorLspeed
	global motorRspeed
	global acceleration
	global speedstep
	global spotturn
# dann ist ein Drehen auf der Stelle moeglich.
	if(spotturn == "left" and acceleration == 0):
		spotturn = "right"
	if(motorLspeed < motorRspeed):
	else:
		motorRspeed = motorRspeed - speedstep
	valueL = valueL/100
	valueR = valueR/100
# ButtonStop ist der Stop Knopf und haelt das Raspberry PI Auto an.
@webiopi.macro
def ButtonStop():
	stop()
initiate()
# starten des Web-Servers und vergabe der Zugangsdaten
server = webiopi.Server(port=8000, login="webiopi", password="raspberrypi")
# Hier werden die Buttons mit den definierten Funktionen hinterlegt
server.addMacro(ButtonForward)
server.addMacro(ButtonStop)
server.addMacro(ButtonReverse)
server.addMacro(ButtonTurnRight)
server.addMacro(ButtonTurnLeft)
webiopi.runLoop()
server.stop()
When i look into some projects using webiopi to control gpio everywhere is same start with import webiopi , GPIO = webiopi.GPIO ... for example here : http://webiopi.trouch.com/Tutorial_Basis.html
