sim_tcr
web based gui crontab editor for raspbian?
Mon Oct 05, 2015 11:51 am
Is there any web based gui crontab editor for raspbian?
So we can design the cron in the gui and save and it is being installed on actual crontab?
Thanks,
Simon Mandy
http://raspisimon.no-ip.org
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
W. H. Heydt
Re: web based gui crontab editor for raspbian?
Tue Oct 06, 2015 1:56 am
You can use any editor you want for crontab. For immediate use, enter the command "export EDITOR=<full path to your editior of choice>", e.g. "export EDITOR=/usr/bin/vi". To set the default editor permanently, add the command to the end of /etc/profile .
rpdom
Tue Oct 06, 2015 4:49 am
I have the following in my ~.bashrc
# if running X, set the default editor to Geany
if [ "$DISPLAY" != "" ]
then
  EDITOR="/usr/bin/geany"
  export EDITOR
fi
If I invoke "crontab -e" from a terminal session on the desktop it uses Geany as the editor. If I do it from a text console it uses teh default editor (vi in my case).
sim_tcr
Tue Oct 06, 2015 6:19 am
I think i did not write enough in my first post.
What i am looking for is, a tool where we can enter the time/interval/schedule in a simple way and the tool set it to crontab.
rpdom
Tue Oct 06, 2015 6:26 am
I think any front-end to crontab will either have limited functionality or will end up horrendously complicated.
Basic crontab entries are not that hard to follow.
