Battery Power a Pi with Camera?
Posted: Sat Oct 03, 2015 9:11 pm
by Sentinelace
I am running Motion Pie which is working great. However where I want to location the pi has no outlet. Is i possible to get battery power to the pi that can last a month? or couple weeks?
Re: Battery Power a Pi with Camera?
Posted: Sat Oct 03, 2015 9:43 pm
by Higgs
For anything to run long on a battery it would have to put the RPi to sleep when not used for it's purpose (like no movement detected).
http://spellfoundry.com/sleepy-pi/sleepy-pi-faq/
However, you can see that this approach then requires the Pi to boot-up again, which can take 25-30 secs with a standard Raspbian image - which means your subject could be long gone by then.
I tried once (just for the heck of it) hot-wiring an ATTiny chip to a motion sensor and a cheap keychain camera (with micro-SD storage) to make it take either a sequence of pictures or some limited-time video clips when the sensor detected motion (it was more sensitive than the motion detection built into the camera). The time to wake up the ATTiny and power-on the camera to start taking vid was about 12 secs (mostly waiting for the cheap camera to start taking vid - it required press/hold a few secs of a button to signal the camera to start recording, which was automated via the ATTIny). The sensor drew <50ua waiting to trigger the sleeping ATTiny.
CORRECTION: It took about 6 secs to start taking vid. 12 secs was the time gap between the end of a vid, powering down, and then immediately powering up again to take another vid.
Posted: Sun Oct 04, 2015 9:36 am
by Burngate
Rough figures:
The Pi takes 1A (maybe less, but that makes the arithmatic easy) at 5v, so 5W
With 24 hours in a day, 7 days in a week, and 4 weeks in a month, that's 700 hours (ok, 672, but some months have more than 4 weeks)
So 3500 Watt-hours.
A quick look on EuroCarParts tells me my Volvo uses a 73 AH battery. Rounding that to 70, and assuming 10v rather than 12v, gives 700 watt-hours.
So five of those would run a Pi for a month. Probably.
Posted: Sun Oct 04, 2015 4:03 pm
by Sentinelace
well crap. I"ll have to get an outlet then
