- - Powered 4-port USB Hub
- USB 3G Modem
- USB Wireless Adapter
- USB to SATA bridge
- USB Keyboard
I powered all device including the hard disk and Pi itself using a lightly modified 480W ATX power supply (my modification was done to add microUSB connector to power the pi, a switch to power on the PSU via green wire, and soldered 5v line to the USB hub).
My questions are:
- Am I doing it right from perspective of power consumption and safety?
Is there any other way (or any other kind of power supply) that is better for this purpose?
Assuming 100% efficiency, will the power supply consume 480W (max rated) or just as needed?
