abfalleimer
Re: Guide: Chromium 51 on Raspbian Jessie
Fri Nov 18, 2016 10:23 pm
Hi all,
kusti8 maybe I am "one of the 8 missing types of person from your footer" ;) or we have some misunderstanding caused by my bad english!
kusti8 wrote:Where did you get that? He's saying that it would only work for YouTube
I have to admit that I read it between the lines.
kusti8 wrote:while my extension used to do hundreds of websites
with chrome-extension permissons set only to youtube ? hundreds of websites ?
https://github.com/kusti8/RPi-chromium/ ... ifest.json
Line 17/18
kusti8 wrote:There is no real way you could do this other than making a button for an extension and then adding omx://.
Did I say something else ? See my 1.
abfalleimer wrote:1. A simple chrome-extension that converts all "watch?v=" links inside the current tab after clicking, from http to a custom protocol called "omx"
kusti8 wrote:you just have to do what the user asks.
I am the user! Your lack of time ( don't get me wrong I fully accept that fact ), put me in this situation to be a "developer"!
bye Abfalleimer
kusti8
Fri Nov 18, 2016 11:03 pm
It does work with hundreds of websites. That line is to pause the video, which it does not do for other sites, but since omxplayerGUI and youtube-dl handle it, it supports many websites.
abfalleimer
Sat Nov 19, 2016 12:09 am
kusti8 wrote:It does work with hundreds of websites. That line is to pause the video, which it does not do for other sites, but since omxplayerGUI and youtube-dl handle it, it supports many websites.
OK I apologize, just saw your "onclick listener" calls the "omx_run" event for every click!
But if you asume that the user "knows what he is clicking" ( only on video links on websites that are supported by youtube-dl ), then my omx protocol changer solution will also work for all 600+ sites! The chrome-extension I wrote could simply replace all links inside the active tab and change the "protocol to omx".
After the click on the converted omx-link the href-value is passed to my shell-script that calls your "start_ytdl_server.sh" and "omxplayergui.py ytdl" afterwards.
I use the "watch?v=" criteria right now also to change the link color of the youtube links to red so you can see that the click on the extension worked / did something!
I will try to record a demonstration video tommorrow.
Bye Abfalleimer
abfalleimer
Sat Nov 19, 2016 7:29 pm
Hi, here is the short video ( a little late, but it was a busy day )
https://yadi.sk/i/dwDi5yuLz2e7C
works with the latest Chromium-Browser plus future releases, and can delegate all clicked links to e.g. youtube-dl/omxplayer.
Works on every website that uses normal "<a href="http://link-to-video-file>" syntax and is supported by youtube-dl.
If someone is interested in this solution at all... let me know. I am totaly happy with this, how could it be otherwise :roll:
Next project for the cold winter days ( if time allows it ), nice QT5 GUI for omxplayer or maybe a complete custom Video-Player using QT5 Media-Libs ( educational purposes ), looks like that there are custom build Raspberry Pi QT5 libraries with RPi Video-Hardware acceleration avaible.
bye Abfalleimer
kusti8
Mon Nov 21, 2016 8:21 pm
abfalleimer wrote:Hi, here is the short video ( a little late, but it was a busy day )
bye Abfalleimer
Nice
abfalleimer
Mon Nov 21, 2016 10:58 pm
I will put a short howto / install-tutorial online tomorrow ( hopefully ).
by AE
Btw: Please stop trying to get into my yadi.sk account, the account is already "cancled" due to "unusual login activities".
fabycyberbob
Fri Jan 13, 2017 1:51 pm
Dear all,
I have the Raspberry pi 3, and Raspbian via NOOBS, latest update/upgrade January 2016.
"Chromium 51.0.2704.91 Built on Ubuntu 14.04, running on Raspbian 8.0" installed.
I Have added the "rpi-youtube" utility following this guide:
http://kusti8.me/RPi-chromium/
then "run_omxplayer.py" twice...
After, I added the rpi-youtube extension in chromium.
The issue is that, in www.youtube.com I start to play a video,
but NO POP-UP or prompt for request to play video with Omxplayer come out!
NOTE:POP UP allowed for www.youtube.com and Ublock Origin stopped.
What I can check??
Fri Jan 13, 2017 2:46 pm
fabycyberbob wrote:Dear all,
The issue is that, in http://www.youtube.com I start to play a video,
NOTE:POP UP allowed for http://www.youtube.com and Ublock Origin stopped.
What I can check??
Asked and answered here: viewtopic.php?f=28&t=171344&p=1097579#p1097579
Retired disgracefully.....
victagayun
Wed Feb 08, 2017 2:22 am
Maybe off topic. My system is Rpi3 Jessie 8.0 (pixel).
I am "now" having problem with chromium when using skype to call (web.skype.com).
Previously, the other end can hear and see my usb camera (with built-in mic).
But now for whatever reason, it crashes.
Previously (when it was still ok),when you start a call, the camera would show and the other end would receive my call. But now when you start a call, my usb camera view would not show anymore and chromium would crash and exit.
I dont know correctly what I have installed or did, maybe it was the quicktime (to view my IPCAM but after install wasnt able to do anyway) or when I modify my alsa setting for espeak.
Anyway, what I plan to do is remove and re-install chromium.
How to remove? Is it like this?
sudo apt-get --remove purge chrom*
And how to install again?
Anyway, the camera is still viewable by motion by other's (PC) browser.
Thanks!
kusti8
Wed Feb 08, 2017 7:34 pm
To reinstall fully :
sudo apt-get purge chromium-browser
sudo apt-get install chromium-browser
What is the output if you run Chromium in the terminal and the issue occurs? What version are you using?
victagayun
Wed Feb 08, 2017 11:34 pm
kusti8 wrote:To reinstall fully :
I am using the stock Chromium in raspbian 8.0, I think version 51 on Ubuntu 14.04 as shown in "About"
cjan
Thu Feb 09, 2017 12:24 am
today Gmail popup a banner warning that didnt support recent version, ask for update version.
ps. im used Pixel's chromium.
Thu Feb 09, 2017 12:41 am
I was under the impression this whole thread refered to the pre Raspbian Jessie Pixel Chromium and therefore now redundant !!!!!
Xterminator
Wed Apr 12, 2017 7:24 pm
Does not work, it says "no valid openPGP data found"
Any solutions for this?
kusti8
Wed Apr 12, 2017 9:19 pm
Xterminator wrote:Does not work, it says "no valid openPGP data found"
The latest raspbian Jessie has chromium included.
Thu Apr 13, 2017 12:10 am
Therefore you have not fully updated Raspbian Jessie with Pixel... chromium-browser is now v54 !
kusti8
Thu Apr 13, 2017 12:11 am
I think you mean v56
Thu Apr 13, 2017 4:12 am
kusti8 wrote: I think you mean v56
Yes v56 :oops:
Version 56.0.2924.84 Built on Ubuntu 14.04, running on Raspbian 8.0
cjan
Tue May 16, 2017 11:52 pm
does chromium transparent? always click background apps.
if so, how to disable it?
runboy93
Wed May 17, 2017 3:13 am
Chromium is 58
GameKyuubi
Sun Jun 04, 2017 7:56 am
I've got an issue on Ubuntu MATE. I've installed Chromium, grabbed the github repo and run install.sh, installed the plugin for Chromium. When I hit the plugin button, omxplayer opens for a split second and then closes. Any ideas?
kusti8
Sun Jun 04, 2017 5:30 pm
GameKyuubi wrote:I've got an issue on Ubuntu MATE. I've installed Chromium, grabbed the github repo and run install.sh, installed the plugin for Chromium. When I hit the plugin button, omxplayer opens for a split second and then closes. Any ideas?
I no longer support rpi-youtube and it doesn't work anymore. Gkreidl provides an alternative that should come up in searches.
cjan
Fri Aug 18, 2017 12:22 am
does jessie abandon chromium-60, or can we steal from stretch?
Goruti82
Wed Sep 13, 2017 4:22 pm
Will rpi-youtube work with raspbian stretch? (chromium-browser 60.0.3112.89-0ubuntu0.14.04.1.1010)
BTW, I am also looking for chromium (60.0...) with Widevine Support... Any idea?
Thanks!
kusti8
Thu Sep 14, 2017 11:18 am
Rpi-youtube is no longer supported and I made have time to make a widevine version this weekend.
