Page 35 of 39
Re: Guide: Chromium 51 on Raspbian Jessie
Posted: Sun Sep 11, 2016 12:56 pm
by Dis93
Thanks, kusti8, that fixed it.
Posted: Tue Sep 13, 2016 11:05 am
by Dr1Agon
just recently did an update/upgrade, everything went well, chromium is still working, but when I want to watch something on youtube I get no sound via the RPi-youtube/omxplayerGUI, sound works normally anywhere else, just not there!
any help would be greatly appreciated!
Posted: Tue Sep 13, 2016 4:02 pm
by gkreidl
Dr1Agon wrote:just recently did an update/upgrade, everything went well, chromium is still working, but when I want to watch something on youtube I get no sound via the RPi-youtube/omxplayerGUI, sound works normally anywhere else, just not there!
HDMI or analog audio?
Posted: Tue Sep 13, 2016 9:24 pm
by Dr1Agon
Oops!
Sorry should have put that in;
Analog
Posted: Wed Sep 14, 2016 1:54 am
by gkreidl
Dr1Agon wrote:Oops!
Analog
Select the "analogaudio" preset (open omxplayerGUI frontend, click on "Settings", then click the preset button).
Posted: Wed Sep 14, 2016 6:18 am
by gambrogi
I tried to install Chromium 45, 48 and 51, via wget/dpkg or via ppa/apt-get install and all the installations gives me an chromium-browser that crashes with the only message illegal instruction, and no more messages. Just Illegal Instruction. :cry:
I have an RPi2 with Jessie and uname -a retrieves:
Linux raspberrypi 4.4.20+ #909 Tue Sep 13 16:41:32 BST 2016 armv6l GNU/Linux
I read this thread and tried all the answers that gives a different installation.
Any can help me? Which is the problem? Thanks.
Posted: Wed Sep 14, 2016 9:14 am
by Dr1Agon
Thanks!, that's solved it!...
although i'm pretty sure i already tried that before posting without success, must not have...
oh well, working now!
Posted: Wed Sep 14, 2016 11:04 am
by kusti8
gambrogi wrote:I tried to install Chromium 45, 48 and 51, via wget/dpkg or via ppa/apt-get install and all the installations gives me an chromium-browser that crashes with the only message illegal instruction, and no more messages. Just Illegal Instruction. :cry:
That is not a Pi2. There is an experimental version linked in the first post you can try.
Posted: Fri Sep 16, 2016 3:25 pm
by Icestar65
Hi there, I am running into a strange issue with Chromium 51 running on Jessie. I run a dashboard with a tab-cycling plugin and after a few days, the browser will start to crash and cannot be reopened. When I try to reopen Chromium from the terminal, I get a "Segmentation Fault" and it does not open.
When I reboot the system, the browser will be able to start up again for a few hours, but it will ultimately crash again with Segmentation Fault until another restart. What is puzzling is that it runs stable for a few days until the first crash, and then it will crash much faster afterwards.
I've tried --disable-gpu, --no-sandbox, and --disable-pinch all to which does not resolve the issue. Any help would be appreciated. Thanks.
Posted: Fri Sep 16, 2016 6:28 pm
by kusti8
Icestar65 wrote:Hi there, I am running into a strange issue with Chromium 51 running on Jessie. I run a dashboard with a tab-cycling plugin and after a few days, the browser will start to crash and cannot be reopened. When I try to reopen Chromium from the terminal, I get a "Segmentation Fault" and it does not open.
Is segmentation fault all that is printed? Can you add --enable-logging=stderr -v=1
To get all the logs.
Posted: Tue Sep 20, 2016 2:23 pm
by Icestar65
Thanks for your reply, the error occurred again today and from the terminal I tried the logging command but I still only get Segmentation Fault. Is there any other way to gather the logs?
pi@raspberrypi:/var/log $ chromium-browser --enable-logging=stderr --v=1
Segmentation fault
Thanks!
Posted: Tue Sep 20, 2016 6:31 pm
by kusti8
That's weird. I would try reinstalling a test image and see if it still works. Chromium does have issues with staying open for a few days just because it uses so much RAM, but it shouldn't cause a segmentation fault.
Posted: Wed Sep 21, 2016 3:24 pm
by Icestar65
kusti8 wrote:That's weird. I would try reinstalling a test image and see if it still works. Chromium does have issues with staying open for a few days just because it uses so much RAM, but it shouldn't cause a segmentation fault.
Sure thing, Ill try to install one of the Chromium test builds, I'm not too familiar with this, how would I be able to do that? Is it from apt-get? I see versions 51 to 45 in there. Thanks!
Posted: Wed Sep 21, 2016 6:25 pm
by kusti8
No, just do the instructions at the top. The experimental builds will make no difference here.
Posted: Tue Sep 27, 2016 11:44 pm
by jakky567
Hi, I've been using your browser and I'm having issues signing in with chrome sync (I use it for cloudprint a lot)
Posted: Tue Sep 27, 2016 11:46 pm
by kusti8
jakky567 wrote:Hi, I've been using your browser and I'm having issues signing in with chrome sync (I use it for cloudprint a lot)
You need to give way more info. What is the error and what are the issues and are you sure your network works right?
Posted: Wed Sep 28, 2016 1:35 am
by jakky567
The chrome sync sign in under settings is stating it cannot sign in, and to try again later. I'm not having issues with any other device. I'd rather use chromium because it handles network loss and reboots with grace.
Posted: Wed Sep 28, 2016 1:36 am
by jakky567
Unfortunately my network is running perfectly.
Posted: Wed Sep 28, 2016 9:27 am
by Dis93
With a version of Chromium being added to the official distro, what will happen to your Chromium project?
I haven't added the 'official' Chromium but I notice on screenshots that the 'official' version has a blue topbar inherited from the new Pixel desktop.
I'm also getting the sync failure triangle icon on my Chromium, despite signing in again.
Posted: Wed Sep 28, 2016 10:09 am
by kusti8
Dis93 wrote:With a version of Chromium being added to the official distro, what will happen to your Chromium project?
This chromium project I'm going to let die. I'm still working with the RPF to add some fixes to their version of Chromium.
Does the version in the official repos work with sync?
Posted: Wed Sep 28, 2016 10:25 am
by Dis93
Understandable, kusti8.
Thank you for your work on this project, it made my Pi experience on the 'net much better.
I'll uninstall your Chromium and try the official one, then see if the sync issue is resolved.
Posted: Wed Sep 28, 2016 11:21 am
by cjan
how to install official chromium?
Posted: Wed Sep 28, 2016 11:22 am
by kusti8
cjan wrote:how to install official chromium?
sudo apt-get update
sudo apt-get install chromium-browser
Posted: Wed Sep 28, 2016 11:41 am
by cjan
sudo apt-get update
O..p, found official=51-Beta, why not .7001 OMG.
Posted: Wed Sep 28, 2016 12:56 pm
by jakky567
Thank you very much for chromium on the pi's. It really is a very solid browser, plus, as a cloudprint solution, is slightly more robust than the headless options.
