kusti8
Re: Guide: Chromium 51 on Raspbian Jessie
Tue Jul 19, 2016 4:32 pm
gkreidl wrote:
MarkHaysHarris777 wrote:kusti8,
... are you still hosting kweb, or have you switched to Chromium (completely) or are they connected in some way?
Are you hosting both?
marcus
kusti8 is hosting the chromium-browser packages - that was his main intent. He is also hosting his own rpi-youtube package which depends on (parts of) the kweb package and so he is also hosting kweb.
Yes correct. I keep the latest version of both packages because my RPi-youtube depends on kweb
MarkHaysHarris777
Thu Jul 21, 2016 5:00 am
marcus
Thanks for the reply... ok... which of the two is (or both) are worth adopting at the moment... I have some folks wanting a recommend, which, I used to recommend kweb, but I'm confused about Chromium atm... and whether it is good, or has too many glitches so far... thanks again for input !
marcus
marcus
:ugeek:
kusti8
Thu Jul 21, 2016 12:17 pm
marcus
marcus
They are very different. Chromium excells at being the best browser in speed, like you would expect on a desktop. It is the fastest and supports the most websites. It rarely crashes. Kweb is excellent at providing a kiosk browser and integrating with the Pi directly (youtube and disabling cache and Java script etc). Try both and see what works. Ultimately, they target different audiences.
SittingDuck
Fri Jul 22, 2016 10:05 pm
im using chromium with the "improved youtube" extension. since i couldnt quite figure out the whole flags / disable DASH thing that you guys are doing (in extensions / options i dont see a "player" option, even with dev. mode on), i just tried different extensions. and this one, after fiddling a little with the options enables me to watch 480p and 360 without interruptions as well. no idea why, since im a noob, but just putting it out there (the extension didnt have a "disable DASH" option though, so its prolly something else, or something related).
also, i was wondering if you had by now fixed the required pi user for youtube-dl? im using another superuser name.
and by the way huge thanks for keeping up the amazing work kusti8 and gkreidl! i'm somewhat poor and thanks to the pi and this chromiumproject i can have it (nearly) all for 50 euros and (even for me) neglectable power costs.
kusti8
Fri Jul 22, 2016 10:55 pm
SittingDuck wrote:im using chromium with the "improved youtube" extension. since i couldnt quite figure out the whole flags / disable DASH thing that you guys are doing (in extensions / options i dont see a "player" option, even with dev. mode on), i just tried different extensions. and this one, after fiddling a little with the options enables me to watch 480p and 360 without interruptions as well. no idea why, since im a noob, but just putting it out there (the extension didnt have a "disable DASH" option though, so its prolly something else, or something related).
Yes, pi is no longer needed. It should just work.
kusti8
Tue Jul 26, 2016 10:06 pm
Kweb 1.7.3 has been released on my repo.
Kratos
Tue Jul 26, 2016 11:01 pm
I really appreciate all your work kusti8! I use it all the time on Ubuntu MATE with no issues whatsoever. Chromium 51 looks very modern with the new makeover. Cheers!
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
jdcrunchman
Fri Jul 29, 2016 7:30 pm
My device doesn't have the memory space for the Chrome browser, so I'm wondering if I can try to install it into another directory.
pi@raspberrypi:~ $ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 3747352 3730968 0 100% /
devtmpfs 469688 0 469688 0% /dev
tmpfs 474004 0 474004 0% /dev/shm
tmpfs 474004 6436 467568 2% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 474004 0 474004 0% /sys/fs/cgroup
/dev/mmcblk0p1 61384 20368 41016 34% /boot
tmpfs 94804 4 94800 1% /run/user/1000
I'm using an 8 gig card.... seems there are other areas that might have enough memory,
I'm basically evaluating all the available browsers to determine which is the best one.
Can the installed browser Epiphany go into Kiosk mode? right now, ANY URL I type into
this browser just returns to the Raspberry Pi desktop and quits the browser. Is there any other
things I have to do to Initialize the browser, or is it because I have no more memory.
I'm new to Linux.
John
kusti8
Fri Jul 29, 2016 9:49 pm
jdcrunchman wrote:My device doesn't have the memory space for the Chrome browser, so I'm wondering if I can try to install it into another directory.
I'm new to Linux.
John
It's because you have no memory. Try
sudo apt-get purge wolfram-engine
As a temporary fix and clean up your space.
gkreidl
Sat Jul 30, 2016 4:07 am
I'm new to Linux.
John
Your system is unusable. You always need some disk space for linux (logs, temp files etc.). Most browsers cache a lot and they keep the cache if not run in private mode. Which means: they collect a lot of data and it is kept on your SD card.
Minimal Kiosk Browser (kweb)
cjan
Tue Aug 02, 2016 11:46 am
hey, just found arch had 52 updated ...
Kratos
Tue Aug 02, 2016 1:56 pm
51 just came out! And I am loving it! I am not ready for a new version! :D
Kratos
kusti8
Tue Aug 02, 2016 1:57 pm
cjan wrote:hey, just found arch had 52 updated ...
Arch maybe, but Ubuntu hasn't released their package yet. I have to wait for that.
HermannSW
Tue Aug 02, 2016 5:30 pm
I read the initial comment and the
THIS WILL ONLY WORK ON A Pi2 AND PI3!
seems to be right.
I did all the installation steps without any issue on Raspberry Pi Zero.
But chromium-browser command does not start with an illegal instruction.
And when started with sudo it silently dies:
pi@raspberrypi01:~ $ chromium-browser
Illegal instruction
pi@raspberrypi01:~ $ sudo chromium-browser
Is there an easy explanation on WHY it is not working on Pi Zero?
Hermann.
viewtopic.php?p=1015300#p1015300
https://stamm-wilbrandt.de/2wheel_balancing_robot
kusti8
Tue Aug 02, 2016 5:40 pm
This is currently compiled for ARMv7 which is not compatible on ARMV6 as you have seen. If it were compiled for ARMv6, then it would work.
Tue Aug 02, 2016 6:04 pm
HermannSW wrote: Is there an easy explanation on WHY it is not working on Pi Zero?
Yes the RPi Zero is ARMv6 same as all the RPi 1's
The information is out there....you just have to let it in.
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
bonzothecat
Sun Aug 07, 2016 12:16 am
This worked last week, but now when I try to add the key I get no valid pgp information and after doing sudo-apt update I get an error Not Found [IP:108.168.243.150 80]. I really liked the touchui and then my sd card was corrupted and I am trying a new install and what worked last week does not seem to work now. Any assistance would be greatly appreciated.
kusti8
Sun Aug 07, 2016 12:02 pm
bonzothecat wrote:This worked last week, but now when I try to add the key I get no valid pgp information and after doing sudo-apt update I get an error Not Found [IP:108.168.243.150 80]. I really liked the touchui and then my sd card was corrupted and I am trying a new install and what worked last week does not seem to work now. Any assistance would be greatly appreciated.
What is the full output and the contents of /etc/apt/sources.list
raspremo
Wed Aug 10, 2016 10:49 am
I subscribed just to say THANK YOU to kusti8!!
Without your work, my RPi3 would be useless for web browsing! The default "Web" Epiphany crashes, lacks a lot of features and is not compatible with most sites.
I disabled smooth scrolling in Chromium and works very well on normal web sites, I don't even turn on my i5 notebook when I go back home in the evening :)
RichardUK
Fri Aug 12, 2016 7:11 pm
Thanks for you great work. Chrome is so much faster on my RPi3 than Epiphany. :)
Is this because it's targeted for the newer arch?
kusti8
Fri Aug 12, 2016 7:13 pm
RichardUK wrote:Thanks for you great work. Chrome is so much faster on my RPi3 than Epiphany. :)
No, probably not. Just because it is designed to be multicore and faster.
putrikumaladewi
wh i can't install
Fri Aug 12, 2016 10:53 pm
sudo apt-get install chromium x11-xserver-utils unclutter
Reading package lists... Done
Building dependency tree
Package chromium is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
chromium-inspector chromium-bsu
E: Package 'chromium' has no installation candidate
treeHouse
Sat Aug 13, 2016 1:58 am
What components would I need to get this to work on Arch, or is it even possible?
Sat Aug 13, 2016 5:38 am
treeHouse wrote:What components would I need to get this to work on Arch, or is it even possible?
If you have a RPi 2B or 3B then ArchLinuxArm has Chromium Browser in the Repository:
https://archlinuxarm.org/packages/armv7h/chromium
If you have issues with install the please start a NEW Post in the Arch Section thank you:
viewforum.php?f=53
kusti8
Re: wh i can't install
Sat Aug 13, 2016 10:43 am
putrikumaladewi wrote:sudo apt-get install chromium x11-xserver-utils unclutter
Follow the instructions in the first post if you have a Pi 2 or Pi3
