Page 26 of 39
Re: Guide: Chromium 50 on Raspbian Jessie
Posted: Sun May 29, 2016 1:08 am
by cjan
kusti8 wrote:cjan wrote:/etc/chromium-browser/default can not add 2 options? flashplugin was gone.
Did you add a space? Can you paste the file?
CHROMIUM_FLAGS="--ppapi-flash-path=/usr/lib/chromium-browser/plugins/libpepflashplayer.so --ppapi-flash-version=21.0.0.182-r1 -password-store=detect -user-data-dir"
CHROMIUM_FLAGS="--disable-gpu"
Posted: Sun May 29, 2016 3:14 am
by kusti8
Remove the second line and add --disable-gpu to the first at the end with a space. You're overwriting the first with the second so it doesn't work.
Posted: Mon May 30, 2016 4:10 am
by shadowbyte
Has Chromium been added officially at this point?
For some reason I was able to do an apt-get update and apt-get install chromium-browser tonight successfully.
It's fast and makes using the Raspberry Pi on the web feel normal again.
Shadow
Posted: Mon May 30, 2016 10:09 am
by gkreidl
shadowbyte wrote:Has Chromium been added officially at this point?
Shadow
Check your sources.list
It's not in any of the main repositories.
Posted: Mon May 30, 2016 1:21 pm
by Zofiel
Any idea to fix Speech synthesis API (Text To Speech) ?
thanks in advance!
Posted: Mon May 30, 2016 9:12 pm
by kusti8
Zofiel wrote:Hi,
thanks in advance!
See this discussion:
viewtopic.php?p=964842#p964842
Posted: Tue May 31, 2016 12:09 pm
by Zofiel
kusti8 wrote:Zofiel wrote:Hi,
thanks in advance!
yes, I reviewed this post before reply. I have the same problem, SpeakIt works one time, after that I have to restart the browser to work It again.
Posted: Tue May 31, 2016 6:25 pm
by JumpZero
Hi kusti8,
Thanks and congratulations for you work: awesome!
For my 8th Pi (a Pi 3) I decided it was time to try the GUI (all my others Pi are running headless, text only). I then followed your instructions to install Chromium. Everything smooth even it opens for first time on the page to install your youtube plugin. So easy to install and browsing the web on Pi 3 is perfectly acceptable.
100% good
Jmp0
Posted: Tue May 31, 2016 7:24 pm
by gkreidl
By default Speakit uses some kind of web service. It may have some usage limitations. And sometimes it takes a long time to start at all.
Posted: Wed Jun 01, 2016 8:10 am
by acrogenesis
Hi @kusti8, with the release of chromium v50 video loading on websites and animations have started to stutter where it didn't before. Do you know if there's something I have to change or how to fix this?
I've rolled back to v49 and it's working great again.
sudo apt-get install chromium-browser=49.0.2623.108-0ubuntu0.14.04.1.1113 chromium-codecs-ffmpeg-extra=49.0.2623.108-0ubuntu0.14.04.1.1113
Posted: Wed Jun 01, 2016 8:33 am
by gkreidl
acrogenesis wrote:Hi @kusti8, with the release of chromium v50 video loading on websites and animations have started to stutter where it didn't before. Do you know if there's something I have to change or how to fix this?
Try this fix:
viewtopic.php?f=66&t=148452
Posted: Wed Jun 01, 2016 9:22 am
by bobbybouwmann
I'm getting these errors since this morning when I ran the command below? Something wrong after updating maybe?
sudo apt-get install chromium-browser rpi-youtube -y
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/c/chromium-codecs-ffmpeg-extra/chromium-codecs-ffmpeg-extra_50.0.2661.102-0ubuntu0.14.04.1.1117_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/chromium-codecs-ffmpeg-extra_50.0.2661.102-0ubuntu0.14.04.1.1117_armhf.deb -> /var/cache/apt/archives/chromium-codecs-ffmpeg-extra_50.0.2661.102-0ubuntu0.14.04.1.1117_armhf.deb).
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/c/chromium-browser/chromium-browser_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/chromium-browser_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb -> /var/cache/apt/archives/chromium-browser_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb).
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/c/chromium-browser-l10n/chromium-browser-l10n_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/chromium-browser-l10n_50.0.2661.102-0ubuntu0.14.04.1.1118_all.deb -> /var/cache/apt/archives/chromium-browser-l10n_50.0.2661.102-0ubuntu0.14.04.1.1118_all.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/webkitgtk/libjavascriptcoregtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libjavascriptcoregtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb -> /var/cache/apt/archives/libjavascriptcoregtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmbim/libmbim-glib4_1.10.0-2.1_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libmbim-glib4_1.10.0-2.1_armhf.deb -> /var/cache/apt/archives/libmbim-glib4_1.10.0-2.1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/modemmanager/libmm-glib0_1.4.0-1_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libmm-glib0_1.4.0-1_armhf.deb -> /var/cache/apt/archives/libmm-glib0_1.4.0-1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libq/libqmi/libqmi-glib1_1.10.2-2_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libqmi-glib1_1.10.2-2_armhf.deb -> /var/cache/apt/archives/libqmi-glib1_1.10.2-2_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/webkitgtk/libwebkitgtk-1.0-common_2.4.9-1~deb8u1+rpi1_all.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libwebkitgtk-1.0-common_2.4.9-1~deb8u1+rpi1_all.deb -> /var/cache/apt/archives/libwebkitgtk-1.0-common_2.4.9-1~deb8u1+rpi1_all.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/webkitgtk/libwebkitgtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libwebkitgtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb -> /var/cache/apt/archives/libwebkitgtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/geoclue-2.0/geoclue-2.0_2.1.10-2_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/geoclue-2.0_2.1.10-2_armhf.deb -> /var/cache/apt/archives/geoclue-2.0_2.1.10-2_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmbim/libmbim-proxy_1.10.0-2.1_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libmbim-proxy_1.10.0-2.1_armhf.deb -> /var/cache/apt/archives/libmbim-proxy_1.10.0-2.1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/modemmanager/modemmanager_1.4.0-1_armhf.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/modemmanager_1.4.0-1_armhf.deb -> /var/cache/apt/archives/modemmanager_1.4.0-1_armhf.deb).
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/r/rpi-youtube/rpi-youtube_5.0.1-1.deb rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/rpi-youtube_5.0.1-1_armhf.deb -> /var/cache/apt/archives/rpi-youtube_5.0.1-1_armhf.deb).
E: Aborting install.
Posted: Wed Jun 01, 2016 11:07 am
by kusti8
Do you have enough space? Something is wrong with your filesystem and it may be corrupted. Try starting new.
Posted: Thu Jun 02, 2016 9:11 am
by torekk
How would I go about if I want to basically disable chromium's cache to reduce disk usage? I already tried the "--disk-dir-cache-size=N" flag with no effect and then just simply set ".cache/chromium" to read-only, which seems to work, but I don't know if that's the proper way.
Posted: Thu Jun 02, 2016 11:10 am
by kusti8
torekk wrote:How would I go about if I want to basically disable chromium's cache to reduce disk usage? I already tried the "--disk-dir-cache-size=N" flag with no effect and then just simply set ".cache/chromium" to read-only, which seems to work, but I don't know if that's the proper way.
That seems the only way, but are you sure you're seeing significant disk usage from caching ?
Posted: Thu Jun 02, 2016 5:06 pm
by torekk
kusti8 wrote:That seems the only way, but are you sure you're seeing significant disk usage from caching ?
I'm not sure, but as long as chromium runs the green LED flashes more frequently than it does when I close chromium. I'm also using the Pi as a desktop replacement, so I'm basically trying to increase the lifetime of the SD card until I get an external harddrive.
Posted: Thu Jun 02, 2016 7:06 pm
by kusti8
torekk wrote:kusti8 wrote:That seems the only way, but are you sure you're seeing significant disk usage from caching ?
I wouldn't worry about it. Good SD cards last a long time and I doubt this will make any difference.
Posted: Thu Jun 02, 2016 8:25 pm
by gkreidl
kusti8 wrote:torekk wrote:kusti8 wrote:That seems the only way, but are you sure you're seeing significant disk usage from caching ?
All browsers cache a lot (though kweb has an option to disable caching, but it will slow down web access) and it is a wear on the SD card. My first SD card started to wear out after about 6 months. That's when I decided to move the root file system to a HDD. All my RPis are running from HDD now; it's much faster and more reliable - and much more disk space / $ (and I always need a lot).
Posted: Thu Jun 02, 2016 8:26 pm
by kusti8
Huh. I wish Chromium had such an option.
Posted: Thu Jun 02, 2016 8:30 pm
by gkreidl
kusti8 wrote:Huh. I wish Chromium had such an option.
Perhaps you can find something in chrome://flags
Re: Guide: Chromium 49 on Raspbian Jessie
Posted: Fri Jun 03, 2016 3:17 am
by cjan
gkreidl wrote:cjan wrote:[
btw, youtube can not forward play.
This used to work with 49, so maybe there's a bug in this version/build.
this bother me a lot, can be fix?
Posted: Fri Jun 03, 2016 3:19 am
by kusti8
cjan wrote:gkreidl wrote:cjan wrote:[
What is forward play?
Posted: Fri Jun 03, 2016 3:38 am
by gkreidl
Please explain, what you mean. Moving inside the video? I don't have any problem with that.
Posted: Fri Jun 03, 2016 5:19 am
by cjan
gkreidl wrote:Please explain, what you mean. Moving inside the video? I don't have any problem with that.
forward play, jump to next time scope...?
Posted: Fri Jun 03, 2016 5:26 am
by gkreidl
cjan wrote:gkreidl wrote:Please explain, what you mean. Moving inside the video? I don't have any problem with that.
No problem for me. It works as it should. Move the slider to a new position and it starts playing from there.
