Page 25 of 39
Re: Guide: Chromium 49 on Raspbian Jessie
Posted: Wed May 25, 2016 11:05 am
by kusti8
gkreidl wrote:Solution:
add
CHROMIUM_FLAGS="${CHROMIUM_FLAGS} --disable-gpu"
to
/etc/chromium-browser/customizations/00-example
or modify /etc/chromium-browser/default
CHROMIUM_FLAGS="--disable-gpu"
Thanks for this. I'll patch the deb.
Posted: Wed May 25, 2016 12:18 pm
by Ben_is_best
add
to
What happens if you do both?
Posted: Wed May 25, 2016 1:03 pm
by gkreidl
Ben_is_best wrote:gkreidl wrote:Solution:
add
to
You'll add the option twice.
Posted: Wed May 25, 2016 8:52 pm
by saharhostnile
I'll look into it when I have time. I didn't test it with other packages, could you name the ones which are having trouble? You may have have to update those to jessie as well.
Posted: Wed May 25, 2016 10:05 pm
by kusti8
saharhostnile wrote:I'll look into it when I have time. I didn't test it with other packages, could you name the ones which are having trouble? You may have have to update those to jessie as well.
Re: Guide: Chromium 50 on Raspbian Jessie
Posted: Fri May 27, 2016 3:34 pm
by kusti8
Now updated for v50!!!
Update using:
sudo apt-get update
sudo apt-get dist-upgrade
Enjoy!
Posted: Fri May 27, 2016 3:45 pm
by gkreidl
kusti8 wrote:Now updated for v50!!!
Enjoy!
I get an error with apt-get update:
Fehlschlag beim Holen von
http://dl.bintray.com/kusti8/chromium-r ... f/Packages 404 Not Found [IP: 159.122.18.156 80]
Posted: Fri May 27, 2016 3:48 pm
by kusti8
Try again. When trying to download packages right when it is updating can result in some things not found. I just tried it and it worked.
sudo apt-get update
Posted: Fri May 27, 2016 3:56 pm
by Dis93
W: Failed to fetch
http://dl.bintray.com/kusti8/chromium-r ... f/Packages 404 Not Found [IP: 5.153.35.248 80]
I tried it a few times kusti8. I got this error with that IP address rather than the 159.x.x.x one
EDIT: working on fifth attempt
Posted: Fri May 27, 2016 3:59 pm
by kusti8
That's weird. I just did a apt-get update and it worked fine. Try waiting five minutes and try again. When I go to
http://dl.bintray.com/kusti8/chromium-r ... ary-armhf/ I can find Packages.
Edit: Just saw your edit, nice.
Posted: Fri May 27, 2016 4:04 pm
by gkreidl
Now it's working for me, too.
Posted: Fri May 27, 2016 4:15 pm
by ChickenPillow
Well basically I copy and pasted the code into terminal, and after a while it just stays on 'Unpacking nodered (0.13.4-1) over (0.13.4) ...' any ideas on how to work it?
Posted: Fri May 27, 2016 4:16 pm
by kusti8
ChickenPillow wrote:Well basically I copy and pasted the code into terminal, and after a while it just stays on 'Unpacking nodered (0.13.4-1) over (0.13.4) ...' any ideas on how to work it?
That's a problem with apt and not Chromium at all, but:
Should fix it.
Posted: Fri May 27, 2016 4:18 pm
by kusti8
It seems like an ongoing problem. I've just run into it too:
viewtopic.php?f=28&t=149361&p=982507&hi ... ed#p982507
Posted: Fri May 27, 2016 5:40 pm
by Heater
kusti8,
The sudo apt-get update/sudo apt-get dist-upgrade thing has completed fine here. I have no chance to test the resulting installation as I have no screen attached just now.
Thanks for the tremendous effort.
Posted: Fri May 27, 2016 5:44 pm
by kusti8
Heater wrote:kusti8,
Posted: Sat May 28, 2016 6:02 am
by jdenec123
I am going to preface this by saying I am very new to this.
I am trying to install Chromium in OctoPi in order to use TouchUI on a touchscreen through the Raspberry Pi. I am using a guide created by BillyBlaze that references your article in order to install Chromium.
No matter how I type it, I cannot get the second command...
sudo apt-key add -echo "deb
http://dl.bintray.com/kusti8/chromium-rpi jessie main"
...to do anything. It is giving me a "conflicting commands" error.
The command before creates a ton of seemingly random characters. Is that what it's supposed to do?
Thanks for your help!
Posted: Sat May 28, 2016 1:41 pm
by kusti8
You're mixing up the commands. They are there in a specific order with different lines for a reason. Just copy and paste it into the terminal and it will all work. Now I would check that you don't have anything weird in sources.list:
sudo nano /etc/apt/sources.list
Posted: Sat May 28, 2016 4:09 pm
by jdenec123
kusti8 wrote:You're mixing up the commands. They are there in a specific order with different lines for a reason. Just copy and paste it into the terminal and it will all work. Now I would check that you don't have anything weird in sources.list:
Wow. I feel like an idiot now. I thought "|" meant a new line. Like a said, I'm new to this.
Thanks again! Worked perfectly
Posted: Sat May 28, 2016 7:36 pm
by Kratos
After browsing the web for a few days on it (v50), I must say it eats a ton of RAM up. 3 tabs of the forums struggle to stay responsive. I do have 256 MB of RAM set for the GPU, so that may affect it...
Kratos
Posted: Sat May 28, 2016 7:37 pm
by kusti8
Kratos wrote:After browsing the web for a few days on it (v50), I must say it eats a ton of RAM up. 3 tabs of the forums struggle to stay responsive. I do have 256 MB of RAM set for the GPU, so that may affect it...
Kratos
Well that's webpages and webbrowsers for you. 256 MB is a lot though , you don't really need that much.
Posted: Sat May 28, 2016 10:01 pm
by Kratos
Considering that Chromium 50 is running on a PC the size of my wallet (a bit thinner than my wallet fortunately) I am not too concerned about lagginess. I appreciate all the time you have poured into this!
Kratos
Posted: Sun May 29, 2016 12:32 am
by torekk
I had problems with version 49 and 256mb GPU ram as well, since I lowered that to 128mb it isn't as worse.
Also thanks a lot for your work kusti8, really appreciate it. Only got my Pi3 like 2 weeks ago as a temporary desktop replacement and in my opinion it's just amazing that I can even watch YouTube in fullscreen* on this small thing.
*Well it doesn't work for every video, mostly older ones being a problem, but I guess that's due to missing codecs?
Posted: Sun May 29, 2016 12:34 am
by cjan
/etc/chromium-browser/default can not add 2 options? flashplugin was gone.
Posted: Sun May 29, 2016 1:02 am
by kusti8
cjan wrote:/etc/chromium-browser/default can not add 2 options? flashplugin was gone.
Did you add a space? Can you paste the file?
