GTR2Fan
Re: Guide: Chromium 45 on Raspbian Jessie
Tue Feb 09, 2016 3:16 pm
Jaspreet997 wrote:Will the new open GL driver in today's Raspbian works out of the box with Chromium browser?
Anyone tried it ?
I've tried it and the screen refresh rate drops from what appears to be a full 60FPS without it to around 2FPS with it. It may be working properly for other people though.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
kusti8
Wed Feb 10, 2016 12:20 am
Anyone tried it ?
That's weird. I haven't had a time to try the new GL because I've been traveling, but when I tried the VC4 a few months back and everything worked perfectly. WebGL worked great. I'll have to try it. Does it look like the screen refresh is the problem or the speed? Do you see any clues? What happens when you try a WebGL example?
GTR2Fan
Wed Feb 10, 2016 12:33 am
kusti8 wrote:Does it look like the screen refresh is the problem or the speed? Do you see any clues?
It's the speed of the refresh, if that makes sense. Scrolling a webpage up or down shows extremely slow redraws from top-to-bottom. Roughly a 2Hz rate I'd guess.
I didn't get as far as trying any as my two favourite OpenGLES games wouldn't even launch either, so I gave up and disabled it. I suppose it's possible that my install is broken in some way, but I've not got the enthusiasm to go bug hunting right now.
kusti8
Wed Feb 10, 2016 12:35 am
That's OK, thanks. It'll be some time before I can try it, hopefully the weekend. But I understand what you're saying.
cjan
Wed Feb 10, 2016 2:52 am
GTR2Fan wrote:I've tried it and the screen refresh rate drops from what appears to be a full 60FPS without it to around 2FPS with it. It may be working properly for other people though.
which way to test WebGL on chromium? had enable it.
Wed Feb 10, 2016 11:08 am
https://www.scirra.com/blog/ashley/23/h ... berry-pi-2
Bottom of this blog.....
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
Kratos
Wed Feb 10, 2016 3:59 pm
The YouTube issue is fixed in Chromium 48. It worked on Ubuntu MATE at least.
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
kusti8
Wed Feb 10, 2016 8:07 pm
Kratos wrote:The YouTube issue is fixed in Chromium 48. It worked on Ubuntu MATE at least.
Kratos
OK. Thanks. I'll update the instructions as soon as I can. I assume that the debs are in Ubuntu.
kusti8
Thu Feb 11, 2016 11:27 pm
I don't know whats wrong with you. I just installed the OpenGL and scrolling was super smooth. I was actually really impressed with the speed, it was lightning quick, maybe because of the new support, I don't know. But it all works for me.
kusti8
Thu Feb 11, 2016 11:35 pm
Kratos
I can confirm that it now works in Raspbian as well. I will update the instructions.
kusti8
Re: Guide: Chromium 48 on Raspbian Jessie
Thu Feb 11, 2016 11:43 pm
Instructions now updated! Enjoy!
cjan
Fri Feb 12, 2016 12:27 am
kusti8 wrote:Instructions now updated! Enjoy!
thanks, but with new vc4 driver youtube can play 144p only.
kusti8
Fri Feb 12, 2016 12:29 am
Yeah, I noticed, but that's a problem with the vc4 driver, not Chromium.
MrKoolics
Fri Feb 12, 2016 1:56 am
Followed the steps WAY above and the chromium browser seems to be working great. THANKS!!
Raspberry Pi 2 Model B w/ OSMC & Raspberry Pi 3 Model B w/ Raspbian Jesse
AiGreek
Fri Feb 12, 2016 11:25 am
Thanks for the update (48), kusti8.
Ben_is_best
Sun Feb 14, 2016 12:40 am
Thank you.
pire.dejaco
Tue Feb 16, 2016 12:34 pm
kusti8 wrote:Yep, it is hardware accelerated for the Wheezy version. I'm going to see if I have a shot at compiling it with hardware acceleration.
Does chromium v22 support webRTC?
kusti8
Tue Feb 16, 2016 12:51 pm
I don't know try it. BTW, with the new OpenGL driver it should be hardware accelerated.
Tue Feb 16, 2016 12:53 pm
If you want a WebRTC solution look at U4VL
http://www.linux-projects.org/modules/s ... e&artid=14
pire.dejaco
Tue Feb 16, 2016 12:54 pm
I tested on jessie with the new OpenGL driver and chromium v48 but the video rendering is not hardware accelerated (use a lot of CPU)
Tue Feb 16, 2016 12:57 pm
Yes very confusing appending to TWO posts
viewtopic.php?f=91&t=133371#p907099
pire.dejaco
Tue Feb 16, 2016 4:22 pm
The last stable chromium version is 50! Which are the main differences between version 48 and 50?
kusti8
Tue Feb 16, 2016 8:43 pm
pire.dejaco wrote:The last stable chromium version is 50! Which are the main differences between version 48 and 50?
I don't get the obsession with having the latest version of everything. It most probably wouldn't affect what you are doing.
Kratos
Tue Feb 16, 2016 10:22 pm
I also noticed on Chromium 48 that audio playback is phenomenal when played off the web. All the popping and clicking is completely gone! This is huge!
Kratos
Kuthedk
Thu Feb 18, 2016 2:13 am
I am on a fresh install and I am trying to get chromium. I get to the last step and i get a lot of gargley-goop that says dependency problems prevent configuration of chromium-browser-l1on: chromium-browser-l1on depends on chromium-browser howerver package chromium-browser is not installed. i think there is something missing in the instructions or something.... or i could have just messed up but please help me.
“Tell me and I forget, teach me and I may remember, involve me and I learn.”
― Benjamin Franklin
“Any fool can know. The point is to understand.”
― Albert Einstein
