cjan
Re: Guide: Chromium 49 on Raspbian Jessie
Fri Jun 03, 2016 6:00 am
gkreidl wrote:
cjan wrote:
gkreidl wrote:Please explain, what you mean. Moving inside the video? I don't have any problem with that.
forward play, jump to next time scope...?
No problem for me. It works as it should. Move the slider to a new position and it starts playing from there.
am using K's 50 and yours?
gkreidl
Fri Jun 03, 2016 7:04 am
cjan wrote: am using K's 50 and yours?
Same.
Minimal Kiosk Browser (kweb)
cjan
Fri Jun 03, 2016 9:23 am
Same.
back to 49, everything back on track.
Scriber
Raspberry Pi Certified Educator
Re: Guide: Chromium 50 on Raspbian Jessie
Mon Jun 06, 2016 7:53 am
Worked well for me! Randomly (or not so) "OK" had also got added to the /etc/apt/sources.list file so had to remove with nano.
@scriberuk
kusti8
Mon Jun 06, 2016 10:55 am
Scriber wrote:Worked well for me! Randomly (or not so) "OK" had also got added to the /etc/apt/sources.list file so had to remove with nano.
With the exact instructions that should not happen. You probably mistyped.
There are 10 types of people: those who understand binary and those who don't.
JumpZero
Mon Jun 06, 2016 2:49 pm
Every time I try to open Google drive in Chromium, the system hangs for 1 or 2 minutes, no mouse no keyboard nothing answering. Then the system kills one chromium thread:
dmesg is showing this:
[ 3378.528202] Out of memory: Kill process 1741 (chromium-browse) score 360 or sacrifice child
[ 3378.528254] Killed process 1741 (chromium-browse) total-vm:842972kB, anon-rss:355360kB, file-rss:12868kB
My chromium install is just a few days old and was done as per instructions of this thread (1st post)
Version 50.0.2661.102 Built on Ubuntu 15.04, running on Raspbian 8.0
Only Chromium was running nothing else. Only 3 tabs.
Plain Raspbian Jessie on 16GB SDcard on Pi3.
Annoying but not very important.
Anyway thanks again for making Chromium available on the Pi.
Jmp0
cjan
Fri Jun 10, 2016 12:04 am
chromium can not reply to HOME blog, don't know why?
kusti8
Fri Jun 10, 2016 12:06 am
cjan wrote:chromium can not reply to HOME blog, don't know why?
I have no idea what you are saying. Please elaborate.
cjan
Fri Jun 10, 2016 12:12 am
reply message to... but no show up
https://www.raspberrypi.org/blog/motorised-skateboard/
btw, how bad my english.
kusti8
Fri Jun 10, 2016 12:13 am
That takes some time to show up because they all have to be manually approved. You're doing fine with your English.
cjan
Fri Jun 10, 2016 12:21 am
kusti8 wrote:
cjan wrote:
kusti8 wrote:I have no idea what you are saying. Please elaborate.
it took half an hour? o..p just send it again.
mypifi
Sat Jun 11, 2016 12:32 am
im getting the following after an apt-get update:
Reading package lists... Done
W: Duplicate sources.list entry http://dl.bintray.com/kusti8/chromium-rpi/ jessie/main armhf Packages (/var/lib/apt/lists/dl.bintray.com_kusti8_chromium-rpi_dists_jessie_main_binary-armhf_Packages)
W: You may want to run apt-get update to correct these problems
kusti8
Sat Jun 11, 2016 12:34 am
mypifi wrote:im getting the following after an apt-get update:
You seem to have two entries in /etc/apt/sources.list
Delete one of them. But it's just a warning and doesn't affect anything.
mypifi
Sat Jun 11, 2016 12:43 am
your a star i spent ages trying to figure it out and you solved it in seconds. many many thanks... :D
ADTK
Sat Jun 11, 2016 4:38 pm
First Install - not working.
I select 'Menu / Internet / Chromium Web Browser'
The pointer changes to the timer icon for about 20 seconds, but then nothing happens.
Any ideas what I'm doing wrong?
I've followed the instructions from page one of this post (it is only 4 lines, so not sure how I messed it up...)
viewtopic.php?f=63&t=121195
The OS was freshly built and updated, using the full Jessie image (I tried with the lite version and installed LXDE, but as that didn't work I changed to the full version)
Anywhere I can check logs, or any ideas?
kusti8
Sat Jun 11, 2016 6:55 pm
Are you sure this is on a Pi2 or Pi3?
fisheye16hp
Sun Jun 12, 2016 2:43 pm
RPi newbie here! I am hoping to use Chromium on a kiosk project. I have an RPi3 running Jessie. When trying to follow the steps on page/post 1 of this thread I get 'OK' after the wget cmd, but then after the echo I see this:
E: The method driver /usr/lib/apt/methods/htp could not be found
htp? Shouldn't that be http? What I am doing wrong? Is this an error in the Raspian config?
Thanks in advance for any help!
kusti8
Sun Jun 12, 2016 2:46 pm
What is inside /etc/apt/sources.list:
cat /etc/apt/sources.list
fisheye16hp
Sun Jun 12, 2016 2:52 pm
kusti8 wrote:What is inside /etc/apt/sources.list:
This:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb htp://dl.bintray.com/kusti8/chromium-rpi jessie main
deb http://dl.bintray.com/kusti8/chromium-rpi jessie main
deb http://dl.bintray.com/krusti8/chromium-rpi jessie main
Thank you
kusti8
Sun Jun 12, 2016 2:55 pm
You have a typo and you also ran it 4 times. Once is enough, any upgrade can be gotten by
sudo apt-get update
sudo apt-get dist-upgrade
sudo nano /etc/apt/sources.list and remove everything except one and fix the htp typo on the 4th line.
Dis93
Sun Jun 12, 2016 4:02 pm
ADTK
Tue Jun 14, 2016 5:31 pm
ADTK wrote:First Install - not working.
Apologies, my follow up post was rejected as a duplicate for some reason. I was indeed a Pi1.
Found by:
cat /proc/cpuinfo
http://www.raspberrypi-spy.co.uk/2012/0 ... d-version/
Now retrying with a Pi2
bullen
Thu Jun 16, 2016 6:23 pm
Chromium works fine when you boot it but then if you leave it on without touching the pi for a couple of hours it becomes unusable, completely unresponsive (just scrolling takes like 1 minute). What can cause this?
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
kusti8
Thu Jun 16, 2016 6:24 pm
bullen wrote:Chromium works fine when you boot it but then if you leave it on without touching the pi for a couple of hours it becomes unusable, completely unresponsive (just scrolling takes like 1 minute). What can cause this?
It's a memory hog. But it should last a day.
Edit: What does top say?
lumsdot
Fri Jun 17, 2016 7:03 am
Just installed the latest version of jessie on my pi 3 and installed chromium 50. Works great as it always did.
i tried the chrome://flags trick and disabled the media source api,
and at last youtube browsing works at 360p inside the browser with no pauses or excessive dropped frames.
Plus i tried the online theramin page, not expecting it to work, but it works ok as well
http://femurdesign.com/theremin/
Will chromium browser, ever be installed by default into the rasbian images,
i know this is a touchy subject, but they shoukd think about it.
i mean the default browser they give, uses ' duck duck go' by default
