kusti8
Re: Guide: Chromium 49 on Raspbian Jessie
Sat Apr 16, 2016 6:39 pm
pontypool wrote:run that? how
Enter it into the terminal and press enter.
There are 10 types of people: those who understand binary and those who don't.
rustybolt
Mon Apr 18, 2016 5:54 pm
Hi guys! This is the first post I'm making from my raspberry :). It is running very well and I like the preinstalled programs on Raspbian (especially the free Mathematica suprised me).
I would like to install chromium (that is how I ended up at this thread). I tried to install chromium 49 as suggested in the OP. This worked fine, but it was a little laggy. I tried to enable hardware rendering, but this made chromium so slow that I was unable to use it anymore. Also, the RPi plugin wasn't working, so I was not able to use youtube (it also plays very sloppily through Epiphany). To fix this and a couple of other things I've been messing around with, I did a fresh install of Raspbian.
What is the latest version of Chromium that is compiled for Raspberry pi and has hardware support? I've been reading through this thread, but I couldn't find a clear answer.
Ben_is_best
Mon Apr 18, 2016 7:01 pm
I think it's the Chromium 49 that you can install here. Even though Chromium 50 has come out it hasn't yet been compiled for ARM processors.
kusti8
Mon Apr 18, 2016 7:23 pm
The latest version with hardware support I'd around v22, not very useful. With the OpenGL driver on, hardware acceleration works but I don't see any noticeable difference.
rustybolt
Mon Apr 18, 2016 7:55 pm
Aw bummer. I'll still install chromium 49 then, as Epiphany keeps crashing. Youtube RPi does not work for me.
kusti8
Mon Apr 18, 2016 7:56 pm
rustybolt wrote:Aw bummer. I'll still unstall chromium 49 then, as Epiphany keeps crashing. Youtube RPi does not work for me.
Try
ginstall-ytdl
And then try again. Did you install the extension and click the icon when at a YouTube video?
rustybolt
Mon Apr 18, 2016 8:03 pm
Sorry, I should be more specific :P
Last time everything worked and the RPi icon displayed as an extension, but didn't do anything when I clicked it (while watching a youtube video). I'm trying again now (that is, installing everything).
Edit: I just corrupted the image on my SD card, Raspbian no longer boots. I am writing a fresh image to the SD card and I'll try again.
Koeshi
Mon Apr 18, 2016 8:34 pm
Try
ginstall-ytdl
Is that meant to be run from the terminal? Because I get an error when I try.
kusti8
Mon Apr 18, 2016 8:35 pm
Koeshi wrote:
Try
ginstall-ytdl
Yes, what error do you get?
Koeshi
Mon Apr 18, 2016 8:40 pm
kusti8 wrote:
Koeshi wrote:
kusti8 wrote: Try
ginstall-ytdl
"command not found"
In general Chromium works well for me, but no luck with youtube.
kusti8
Mon Apr 18, 2016 8:43 pm
Try running the instructions again and report what happens.
Koeshi
Mon Apr 18, 2016 8:48 pm
kusti8 wrote:Try running the instructions again and report what happens.
Nothing happens, just get the message
bash: ginstall-ytdl: command not found
kusti8
Mon Apr 18, 2016 9:05 pm
The instructions at the first post.
rustybolt
Mon Apr 18, 2016 10:31 pm
Sorry, I have been busy with setting up Raspbian again. Everything works fine now (finally I have glorious fullscreen smoothly playing), thank you! (I still have no idea what went wrong the first time, sorry for bothering...)
Ben_is_best
Mon Apr 18, 2016 11:02 pm
Koeshi wrote:
"command not found"
That happened to me and I just ran
sudo apt-get install chromium-browser rpi-youtube -y
and it worked.
kusti8
Tue Apr 19, 2016 12:06 am
rustybolt wrote:Sorry, I have been busy with setting up Raspbian again. Everything works fine now (finally I have glorious fullscreen smoothly playing), thank you! (I still have no idea what went wrong the first time, sorry for bothering...)
:D
cjan
Tue Apr 19, 2016 11:55 am
keep cooking, chromium-browser-50.0.2661.75 is out.
kusti8
Tue Apr 19, 2016 12:06 pm
cjan wrote:keep cooking, chromium-browser-50.0.2661.75 is out.
It's not in the Ubuntu repos so I have to wait for that.
cjan
Tue Apr 19, 2016 12:19 pm
found this,
https://launchpad.net/~canonical-chromi ... ld/9579357
kusti8
Tue Apr 19, 2016 12:21 pm
found this,
I can't use that because it's for Xenial and unstable. I need one for trusty.
Ben_is_best
Tue Apr 19, 2016 7:03 pm
found this,
The right one can be found at https://launchpad.net/ubuntu/trusty/arm ... m-browser/.
gkreidl
Tue Apr 19, 2016 8:53 pm
The right one can be found at https://launchpad.net/ubuntu/trusty/arm ... m-browser/.[/quote]
No 50 version. And there's an unmet dependency on Jessie; that's why kusti8 will compile a new version (and has done so for 49).
Minimal Kiosk Browser (kweb)
GICSDNSA
Tue Apr 19, 2016 9:16 pm
I ran your instructions and when I use Chrome now, no matter where I try to go, I get "your connection not private" and it won't let me get to any webpages. I also see "www.google.com normally uses encryption to protect your information. When Chromium tried to connect to www.google.com this time, the website sent back unusual and incorrect credentials. This may happen when an attacker is trying to pretend to be www.google.com, or a Wi-Fi sign-in screen has interrupted the connection. Your information is still secure because Chromium stopped the connection before any data was exchanged.
You cannot visit www.google.com right now because the website uses HSTS. Network errors and attacks are usually temporary, so this page will probably work later." This comes up on all websites tried.
kusti8
Tue Apr 19, 2016 10:04 pm
gkreidl wrote: No 50 version. And there's an unmet dependency on Jessie; that's why kusti8 will compile a new version (and has done so for 49).
Yeah, exactly. I haven't tried compiling the Xenial version or 15.10, but the first one is unstable and might not work well at all with the dependencies. I've written a bot to compile 14.04 versions, and I'll try 15.10 when 50 comes out.
rustybolt
Tue Apr 19, 2016 10:30 pm
I tested my sound today and it works, but for omxplayer I have to include the -o local switch (see this thread). Is there any way to make RPi-youtube run omxplayer with this switch?
