Re: Guide: Chromium 51 on Raspbian Jessie
Yeah I've seen this. I have no idea what is causing this and I have limited time. I don't know if I want to continue with it. I can rework the script a little, but not till this weekend and maybe the next one.
There are 10 types of people: those who understand binary and those who don't.
Could there be a post for changelogs perhaps? Full screen video does not seem to be accelerated.
DELETED IRRELEVENT REPLY
Last edited by fruitoftheloom on Mon Oct 17, 2016 4:16 pm, edited 1 time in total.
My other Linux machine is a ChromeBox
It is accelerated, it's just a bit choppy because, well, it's full screen.jakky567 wrote:Could there be a post for changelogs perhaps? Full screen video does not seem to be accelerated.
A bit choppy? Which screen size do you have?kusti8 wrote:It is accelerated, it's just a bit choppy because, well, it's full screen.jakky567 wrote:Could there be a post for changelogs perhaps? Full screen video does not seem to be accelerated.
Minimal Kiosk Browser (kweb)
- Raspberry Pi Engineer & Forum Moderator
Yes, video decode is fast. Composition of the video with whatever web controls are present by Chromium is the bottleneck.kusti8 wrote:It is accelerated, it's just a bit choppy because, well, it's full screen.jakky567 wrote:Could there be a post for changelogs perhaps? Full screen video does not seem to be accelerated.
It doesn't really matter if source video is SD or HD, its the destination window size that affects performance.
Work is continuing on this, but the path from decoded pixels to screen with Chromium is long and complicated...
1080p. I can still watch it, but it freezes every 5 seconds a little. Cinematic mode works fine.gkreidl wrote:A bit choppy? Which screen size do you have?kusti8 wrote:It is accelerated, it's just a bit choppy because, well, it's full screen.jakky567 wrote:Could there be a post for changelogs perhaps? Full screen video does not seem to be accelerated.
Thank you very much for the explanation.dom wrote:Yes, video decode is fast. Composition of the video with whatever web controls are present by Chromium is the bottleneck.kusti8 wrote:It is accelerated, it's just a bit choppy because, well, it's full screen.jakky567 wrote:Could there be a post for changelogs perhaps? Full screen video does not seem to be accelerated.
Many thanks for the effort!
ERROR:native_process_launcher.cc(137) Can't find manifest for native messaging host run_omx
Manifest is as expected in /etc/chromium-browser/native-massaging-hosts/
Will do further investigation. But due to my lack in experience, don't expect too much.
Rgrds,
Mark
Same issue here. Error-Message:This is what it does:
-by clicking on the button in chromium the YT-playback pauses and nothing else happens
-"omxplayergui ytdl [url]" starts omxplayerGUI and plays the video
Rgrds,
Mark
kusti8's extension is currently broken. For a replacement (though less elegant) see here: viewtopic.php?f=66&t=163018&p=1054095#p1054095markmark wrote:Many thanks for the effort!
Rgrds,
Mark
@gkreidl
OK, thanks for clarifying this.
>For a replacement (though less elegant) see here: view ... 5#p1054095
This is exactly what I was looking for. I really apprechiate this. I already checked out kweb before. Your docs are the best I have seen for years.
Rgrds,
Mark
Rgrds,
Mark
- Location: The unfashionable end of the western spiral arm of the Galaxy
Off-topic troubleshooting split to viewtopic.php?f=28&t=163864&p=1058748
Hi everyone,
I did a fresh Raspian install on a new SD-Card today and ran into the same problems! After running all the install steps the mouse-click on the plugin/extension paused the video...but nothing happened afterwards.
The problem is caused by the newer 51er Chromium versions! ( Why ??? I don't know! If I find some time I will look a little deeper )
The latest working Chromium version is 51.0.2704.79-0ubuntu0.14.04.1.1121
Luckily this working Chromium version is also avaible in kusti8's repository! So if downgrading to the lower/older Chromium version is on option for you then simply deinstall the current Chromium version and install the older one, or wait for a fix.
1. Delete the installed Chromium-Browser
If you already ran kusti8 install.sh script then also delete the following directories
Keep in mind that the next step will delete all your Chromium settings! I'm not sure if this step is needed... I did it.
2. Install the older Chromium version, make sure that kusti8's repository is already inside your /etc/apt/sources.list!
3. Follow the Install-Instructions on kusti8 Github
IMPORTANT
But edit the install.sh file inside the RPi-chromium folder befor you execute it! Otherwise kusti8's install.sh will install the latest Chromium-Browser version which did not work with the plugin.
Simply delete the "chromium-browser" entries in Line 3 and 8 ( it depends on what you did / install before but it is absolutely OK to delete both entries )
The install.sh script should look like this afterwards:
4. Then run the install.sh.
5. Problem solved... now everything should work as expected! At least for me these steps does the trick
Excuse my bad english... bye Abfalleimer
sudo apt-get purge chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra
sudo rm -rf /etc/chromium-browser
sudo rm -rf /usr/lib/chromium-browser
rm -rf ~/.config/chromium
sudo apt-get update
sudo apt-get install chromium-browser=51.0.2704.79-0ubuntu0.14.04.1.1121 chromium-browser-l10n=51.0.2704.79-0ubuntu0.14.04.1.1121 chromium-codecs-ffmpeg-extra=51.0.2704.79-0ubuntu0.14.04.1.1121
git clone https://github.com/kusti8/RPi-chromium
if grep -q "http://dl.bintray.com/kusti8/chromium-rpi" /etc/apt/sources.list; then
sudo apt-get update
#sudo apt-get install chromium-browser kweb -y //Delete the chromium-browser entry
sudo apt-get install kweb -y
else
wget -qO - http://bintray.com/user/downloadSubjectPublicKey?username=bintray | sudo apt-key add -
echo "deb http://dl.bintray.com/kusti8/chromium-rpi jessie main" | sudo tee -a /etc/apt/sources.list
sudo apt-get update
fi
sudo cp native/run_omxplayer.py /usr/bin/
sudo cp native/start_ytdl_server.sh /usr/bin
sudo mkdir /etc/chromium-browser/native-messaging-hosts
sudo cp native/run_omx.json /etc/chromium-browser/native-messaging-hosts/
# You can also comment out the following 2 lines...
#chromium-browser chrome://extensions &
#sudo leafpad /etc/chromium-browser/native-messaging-hosts/run_omx.json
This may be a bad idea. This version (and the older ones by kusti8 as well, e.g., v48; v49; v50), have all had their credential/authentication API keys revoked/disabled by Google.The latest working Chromium version is 51.0.2704.79-0ubuntu0.14.04.1.1121
Try logging into the browser and see what happens.
I myself have managed to get the newer chromium browser (51.0.2704.91) working just fine, and with only slight/minimal issues with Youtube playback. I installed chromium standalone, and then manually installed flash 23 (23.0.0.205). This is what I used. My experience may not be typical though, as I run a custom performance version of Raspbian, that is for multimedia use, and is significantly faster than normal Raspbian/PIXEL (just Google 'pi 3 performance image').
I don't install rpi-chromium-mods at all.
Updating apps and kernel seems to also help with some of the chromium issues.
sudo apt-get update && sudo apt-get upgrade
The rpi-youtube plugin does not work. See here for a workaround:
Hi piuser72,piuser72 wrote: This may be a bad idea. This version (and the older ones by kusti8 as well, e.g., v48; v49; v50), have all had their credential/authentication API keys revoked/disabled by Google.
could you be a little bit more precise ? What do you mean with "credential/authentication API keys revoked/disabled" ?
Could you give me an example of what should not work with the older Chromium version ?
For me the older 51.0.2704.79-0ubuntu0.14.04.1.1121 version works fine... no problems so far! I installed the RPi-youtube plugin from the webstore, no problems! Can surf to any website without any troubles
bye Abfalleimer
It should work fine with the API keys there now. There's a workaround that I linked to if you want to use the latest supported Chromium.abfalleimer wrote:Hi piuser72,piuser72 wrote: This may be a bad idea. This version (and the older ones by kusti8 as well, e.g., v48; v49; v50), have all had their credential/authentication API keys revoked/disabled by Google.
For me the older 51.0.2704.79-0ubuntu0.14.04.1.1121 version works fine... no problems so far! I installed the RPi-youtube plugin from the webstore, no problems! Can surf to any website without any troubles![]()
bye Abfalleimer
Ok thanks for the reply kusti8, I already saw the workaround link! For now I'm fine with my solution.kusti8 wrote: It should work fine with the API keys there now. There's a workaround that I linked to if you want to use the latest supported Chromium.
Do you plan to fix / update your extension to work with the latest Chromium-Browser ?
bye Abfalleimer
No I don't plan to fix it. I've moved onto other projects and I can't figure out why this won't work.abfalleimer wrote:Ok thanks for the reply kusti8, I already saw the workaround link! For now I'm fine with my solution.kusti8 wrote: It should work fine with the API keys there now. There's a workaround that I linked to if you want to use the latest supported Chromium.
bye Abfalleimer
Sad to hear that kusti8... but after looking a little bit into your complete source code ( chrome extension, run_omx.json plus all the other components ), I can understand your decision.kusti8 wrote: No I don't plan to fix it. I've moved onto other projects and I can't figure out why this won't work.
Your solution is quite complex
I tried a different approach today:
1. A simple chrome-extension that converts all "watch?v=" links inside the current tab after clicking, from http to a custom protocol called "omx"
2. Then the only thing you have to do is register this custom omx protocol inside Raspian
3. Now whenever you click on this omx Video Links a shell script is triggered receiving the URL of the clicked video and starts your "start_ytdl_server.sh" and run the "omxplayergui.py ytdl URL" command to play the video!
A little bit easier and far less lines of source code...
I will do some further testing... but looks very promising and working fine so far ( no problems with the latest chromium version ) ! Just need to put all things together and write an install script.
Maybe I should fork your project ?
bye Abfalleimer
This only works for youtube, not for the other 600+ supported websites.abfalleimer wrote:Sad to hear that kusti8... but after looking a little bit into your complete source code ( chrome extension, run_omx.json plus all the other components ), I can understand your decision.kusti8 wrote: No I don't plan to fix it. I've moved onto other projects and I can't figure out why this won't work.
I will do some further testing... but looks very promising and working fine so far! Just need to put all things together and write an install script.
bye Abfalleimer
Hi gkreidl,gkreidl wrote: This only works for youtube, not for the other 600+ supported websites.
yes like kusti8's extension too,
but it should not be too hard to get this working "for the other 600+ supported websites"
Just one 600+ big array of video-website-url's and the corresponding "video-links identifiers", as long as the video websites don't use "tricky tricks" to deliver the video links... everything is possible.
Is there a link to the "600+ websites" ?
bye Abfalleimer
They are changing their methods all the time and they are using dirty tricks. youtube-dl has to adapt to the changes all the time. This will become an endless job for you - as it is for the youtube-dl team.abfalleimer wrote:Hi gkreidl,gkreidl wrote: This only works for youtube, not for the other 600+ supported websites.
bye Abfalleimer
My user script solution doesn't require any changes at all. The only thing you have to do is start ytdl-server manually (or use a script that does it when chromium is started and stops it again afterwards).
youtube-dl has a link to supported websites.
Guenter what was your real intention with this reply ?gkreidl wrote: This only works for youtube, not for the other 600+ supported websites.
Nothing constructive as it turns out...
are you angry that many use your OmxplayerGUI and not your whole "KIOSK" ? Should I write an OmxplayerGUI myself ? is that what you really want and fearing to say! I don't get the point.gkreidl wrote: They are changing their methods all the time and they are using dirty tricks. youtube-dl has to adapt to the changes all the time. This will become an endless job for you - as it is for the youtube-dl team.
bye Abfalleimer
Where did you get that? He's saying that it would only work for YouTube, while my extension used to do hundreds of websites and gkreidl's workaround does do hundreds. There is no real way you could do this other than making a button for an extension and then adding omx://. You cannot maintain a list of the supported websites because they constantly change, you just have to do what the user asks.abfalleimer wrote:Guenter what was your real intention with this reply ?gkreidl wrote: This only works for youtube, not for the other 600+ supported websites.
Nothing constructive as it turns out...are you angry that many use your OmxplayerGUI and not your whole "KIOSK" ? Should I write an OmxplayerGUI myself ? is that what you really want and fearing to say! I don't get the point.gkreidl wrote: They are changing their methods all the time and they are using dirty tricks. youtube-dl has to adapt to the changes all the time. This will become an endless job for you - as it is for the youtube-dl team.
bye Abfalleimer
