exwaver
openelec on raspbian ??
Sat Jul 21, 2012 9:53 am
Is there a version of openelec that will work on the new raspbian package, especially a version that will enable my wifi to work with openelec. I currently have wifi working perfectly on my copy of raspbian.
Cheers
redhawk
Re: openelec on raspbian ??
Sat Jul 21, 2012 10:17 am
I found OpenELEC was more responsive to the keyboard and mouse than Raspbian however when both are playing videos there wasn't much difference.
I didn't compile OpenELEC myself I used the 1GB image file from the following page - http://sparky0815.de/openelec-download- ... fat-files/
Richard S.
exwaver
Mon Jul 23, 2012 5:44 am
can you please tell me how to install openelec on raspbian. I am new to linux and have downloaded the r11594 package but not sure what to do with it.???
masterluke
Mon Jul 23, 2012 6:29 am
See here..
http://www.raspberrypi.org/phpBB3/viewt ... =35&t=9210
..works on debian and raspbian
exwaver
Mon Jul 23, 2012 6:51 am
it worked fine on wheezy but I get an error on raspbian saying it is incompatible with armel, the error gives something like not working with armel, uses armfp (or something similar). I would really like to get this working. I am new to linux and finding that there is a road block at every new corner I turn!!!
eppe
Mon Jul 23, 2012 9:24 am
Any particular reason you prefer using openElec's version ?
You can use XBMC directly on Raspbian.
You'll find instruction to build it yourself or precompiled binaries there :
http://www.raspberrypi.org/phpBB3/viewt ... 66&t=10304
masterluke
Mon Jul 23, 2012 6:06 pm
exwaver wrote:it worked fine on wheezy but I get an error on raspbian saying it is incompatible with armel, the error gives something like not working with armel, uses armfp (or something similar). I would really like to get this working. I am new to linux and finding that there is a road block at every new corner I turn!!!
Did you do a...
sudo dpkg -i --force-architecture openelec_0.1_armel.deb
redhawk
Mon Jul 23, 2012 9:22 pm
This isn't stable enough for me I tried to play some youtube videos but it flashes green.
When I attempt to play mp3s from a shoutcast server the my video output goes nuts.
Maybe this build only works with HDMI it cetainly using stable for composite video use.
Richard S.
masterluke
Tue Jul 24, 2012 5:15 am
You probably need to update the version of openelec in it. The packaged version is quite old.
dom
Tue Jul 24, 2012 8:57 am
redhawk wrote:This isn't stable enough for me I tried to play some youtube videos but it flashes green.
Richard S.
Sounds like you have hdmi audio enabled when using composite. Make sure analogue audio is enabled.
