I'm a super newbie when it comes to the RPi, i dont even own on yet but I have two projects that I want to use a couple of Pis for (a network music player to replace my aging sqeeuzebox and an internet radio).
Naturally like any geek i research the hell out of all of it before i start spending money. I'm generally happy that i can crack on with both projects but I do have a question regarding the use of the GPIO and I2C pins.
This product https://www.adafruit.com/products/1115 says that it only uses the 2 I2C pins on the header but yet when i delved into the assembly instructions there is clearly a stage where you have to solder in a pin block that plugs into ALL of the PI's header pins?
No is it just a case that the whilst all the pins on the LCD board are being plugged into the pi only the I2C ones are actually being used and the others are still able to be used?
Sorry if this is a daft question...as i said.. new to this
