BadFish
1g RAM is not en for use!
Sun Aug 16, 2015 4:46 pm
I just use Raspberry Pi 2B+ to do some works,and i had Overclocked to medium; well,the CPU is sufficient to do more things,but when i check the Memory usage,the is almost no Memory can be used,i look forward the next version will have 2G RAM :D
there is the Memory usage picture(i just run python script with pypy in one process):
Re: 1g RAM is not en for use!
Mon Aug 17, 2015 2:01 pm
Sounds like you application is a memory hog. Most programmes should run fine in 1GB.
My first computer had 16KB of memory. That worked fine....
RaTTuS
Mon Aug 17, 2015 2:05 pm
http://www.linuxatemyram.com/
you are fine
also see
top
Covfefe
Mon Aug 17, 2015 2:08 pm
RaTTuS wrote:http://www.linuxatemyram.com/
you are fine
also see
top
Nice link!!
Mon Aug 17, 2015 2:37 pm
I have yet to run anything on the Pi that might require 2GBytes of RAM. Hardly use a few percent of the 1GBytes normally.
Use the "top" command to see how much memory is used by running processes. I bet your Python program hardly shows up.
RaTTuS
Mon Aug 17, 2015 2:49 pm
you are fine
also see
top
Nice link!!
I used to try and explain how linux uses memory when I found that page waaaaay back .... ;)
Covfefe
metalj
Mon Aug 17, 2015 3:55 pm
Hydrogen don't work and I assume it has something to do with the ram. Also I look forward to speeding up sonic pi. And the PDF viewer is real slow. Nothing I can't deal with.
Backspace 28 times :)
gkreidl
Mon Aug 17, 2015 4:42 pm
@BadFish: Learn to understand the output of 'dfree'. You've got enough RAM.
Minimal Kiosk Browser (kweb)
