bucker
Question about wiring buttons to GPIO
Sat Aug 01, 2015 7:08 pm
I'm currently trying to build a portable handheld console using a Pi, but i'm struggling to find a way to wire this type of buttons to the Pi's GPIO, any help on this?
http://s27.postimg.org/6v4gmhc43/IMG_0325.jpg
thx in advance
Winning is for losers.
Pi Zero W (inside a Pikachu case ;) ) with DietPi running Sonarr,Couchpotato,Pi-hole,Pi-VPN
Pi B running Home Assistant
Pi 2B & HiFiBerry DAC+ running Volumio OS
Pi 3B (inside a genesis case 8-) ) running RetroPie
P_Monty
Re: Question about wiring buttons to GPIO
Sat Aug 01, 2015 7:40 pm
Have you got a connector that the ribbon cable will plug into? If you have, it looks relatively simple..
bucker
Sat Aug 01, 2015 8:10 pm
P_Monty wrote:Have you got a connector that the ribbon cable will plug into? If you have, it looks relatively simple..
thx for the reply,
yes i do, but the problem is that it is soldered to a much bigger board that unfortunetly can't fit in my case, so i have to find a way to wire the ribbon cable to the GPIO...
here is the photo of the connector
front: http://s23.postimg.org/tmrmyith7/IMG_0327_1.jpg
back: http://s22.postimg.org/87vpo0qgx/IMG_0330.jpg
is there any way i can do this without using the original board?
