I'm surprised to read this from you, Dougie. Are you sure someone else (someone sensible) hasn't hacked into your account?If you're a new user you will have a much better experience if you use NOOBS...
You don't need that SD formatter utility for a factory fresh SDCard (if it's less than 64GB), in the unlikely event that it needs re-formatting just stick it in your phone or tablet.
I think you were a victim of old information and/or inertia on the part of advice-givers (and magazine writers) who are used to the old fashioned ("raw image") way of installing and just haven't cottoned to the NOOBS way.nupiuser wrote:Many thanks to all replies by everyone. I did read each one.
I thought it was an indication from the message that I use Windows to do things at the moment because I was asking abt the Windows util, win32diskimager. My bad! This was the utility recommended in the RASPBERRY magazine where I was doing research on the board, software, and other items needed. Matter of fact, this utility was sorta recommended over NOOBS.
NOOBS wins hands down because you only need stock standard Win7, Win8, Win8.1 or Win10 on a laptop with an SDHC card reader to create a bootable SDCard for the RPi. There is NO extra software needed.nupiuser wrote:Many thanks to all replies by everyone. I did read each one.
NOOBS doesn't need ANY extra software everything is built-in to ALL supported versions of Windows.Heater wrote:Ah, Ok. I think I get the idea. NOOBS is a work around for the limitations of Windows operating systems. Fair enough. The instructions for installing NOOBS are more complex than just copying a Raspian image directly to an SD card and require a download from a third party. And I guess they don't work for us Linux users anyway, unless we skip the part about the SD card association formatter.
You've clearly never booted a NOOBS card.Heater wrote: Then there is that extra step of selecting an OS on boot up. Trivial I guess, but probably a mystery if you have no idea about the various options.
FTFY.Heater wrote:A bunch of nonsense...
Is TFM wrong in this case?Your Raspberry Pi will boot, and a window will appear with a list of different operating systems that you can install. We recommend...
No idea what TFM is (some manual?) but that happens on first boot up. Not the best option for headless installs, but most newbies using NOOBS are going have a screen. If only one OS is installed, then you don't choose an OS to boot at all.Heater wrote:Dougie,
No I have not. But for once I did RTFM:Is TFM wrong in this case?Your Raspberry Pi will boot, and a window will appear with a list of different operating systems that you can install. We recommend...
The, cough, fine manual. As in, read the fine manual (RTFM).No idea what TFM is...
Wow! You had bootable CDs??? You must be just a kid.Harking back to the "good old days" of rawrite is not really appropriate: Linux was just a wild idea, an experiment for serious nerds, back then. Besides one soon got a RedHat CD that just booted to what you want.
Actually, I do sorta agree with that. Although, I need to point out that:No, the whole idea of NOOBS is just a work around for the lack of a dd or rawrite type utility in Windows.
