Thu Jul 30, 2015 11:12 am
When you say the switches are working, do you mean that the relays energise (click on)?
If so then I think you have mistaken the way that the relays work, they simply make an electrical contact between switch positions.
You would need to put a voltage onto the common contact of the relay, which would then be switched to either the normally closed (when the relay is off) or normally open (when the relay is on) contacts.
Doug.
