I have the same problem with color but I'm using xrdp to hook to it. I think it's an update because when I was updating mine it started out red and then ran the update the colors got inverted. This is on a raspberry pi b + mind you.jamesh wrote:That sounds like a cabling problem - try reseating the HDMI cable at both ends (You are using HDMI?). Also try another cable.
