rpiswag
What is the best sdr you can buy that costs less than $100?
Fri Jul 24, 2015 2:19 am
What are some good software defined radios that cost $100 or less ($100 is about 91.11 Euros or 64.48 British Pounds)
A computer's power can't be just measured Gigahertz. It is the same thing with us humans.
Jednorozec
Re: What is the best sdr you can buy that costs less than $1
Fri Jul 24, 2015 5:05 am
Are all of the search engines down again?
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
Fri Jul 24, 2015 5:14 am
I think you can get SDR running on a $10 USB DVB-T stick, like the RTL2838 ones that work with the Pi.
The gsearch thing will tell you how.
Fri Jul 24, 2015 8:00 am
Fri Jul 24, 2015 9:11 am
How is it that your Google works and discovers a useful link, but rpiswag finds it 100% impossible to use Google and prefers to post banal questions on here?
This is a doctor free zone.
Fri Jul 24, 2015 9:21 am
...or this one http://garethhayes.net/gnu-radio-for-raspberry-pi
Retired disgracefully.....
......to a more gentile life !
texy
Fri Jul 24, 2015 11:46 am
You are just as bad Dougie -
viewtopic.php?f=63&t=115286&p=791358#p791358
Play nice - if you don't have nothing good to say, then say nothing ;)
Texy
blachanc
Fri Jul 24, 2015 12:31 pm
Would it be possible for people to play nice with kids/teen on this forum?
Or at bare minimum, just ignore their post?
rpiswag is 14
IMHO: sarcasm is the worst teaching tool/technique.
Ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
Fri Jul 24, 2015 12:44 pm
blachanc wrote:Would it be possible for people to play nice with kids/teen on this forum?
rpiswag is 14
Ben
Have you actually read any of RPISWAG early posts :?:
It could be the reason why some of the more active Forum Visitors become frustrated ;)
blachanc
Fri Jul 24, 2015 12:59 pm
I read almost all posts on the forum, I just do not post that much.
and yes there are few many "noisy posters".
The point I was trying to make is (as an exaggerated analogy): If you were to take care of my autistic kid for a week, I could understand that at one point you would loose your temper and hit or verbally abuse him. But, that does not make it ok to do so. ;)
Ben
mahjongg
Fri Jul 24, 2015 2:20 pm
rpiswag wrote:What are some good software defined radios that cost $100 or less ($100 is about 91.11 Euros or 64.48 British Pounds)
I would recommend using an R820T dongle!
They are in the $25 range, and are perfect for SDR.
My "maker club" called "revspace" is using them (as are many others), you can find some more info here:
https://revspace.nl/RevRadio
MarkTF
"Best" depends upon your application. Do you need receive only or do you need Tx/Rx? How much do you value sensitivity and selectivity, etc? If you don't have a specific application in mind and you just want to get your feet wet with SDR, then they're practically giving away DVB-T usb stick receivers, so it's hard to go wrong starting there.
In any case there's a lot of info out there. e.g. http://www.rtl-sdr.com/roundup-software-defined-radios/
rpiswag
Fri Jul 24, 2015 3:38 pm
I would like the sdr to be a full duplex radio. An example of a sdr radio that is full duplex radio is the blade rf but is costs way to much for me to afford.
marked
Fri Jul 24, 2015 3:51 pm
rpiswag wrote:I would like the sdr to be a full duplex radio.
For you to transmit you will need either kit that can only be used within certain frequency ranges (unlicensed like 2.4GHz), or you require a license (AM, FM, amateur radio, etc.).
Please research the necessary license conditions before using any radio transmitter. These include, but are not limited to, passing a written test before obtaining the license.
rpiswag
Fri Jul 24, 2015 4:14 pm
I know you have to have a license but I already have a ham radio license. My uncle has a ham radio and he said I should get a license so I did. The ham radio spectrum is wide and the frequencies I need to use are in the ham radio spectrum.
