KeePass2 auf Raspberry Pi
Posted: Thu Jul 23, 2015 8:02 pm
by DerberMohikaner
my Raspi works like a charm. Perfect.
One problem though.
Today I installed KeePass2 with "sudo apt-get install keepass2". No error messages.
I can call the programm in startx with epiphany webbrowser Menu/Addons/KeePass2. The Raspberry is very busy for a short time und displays the KeePass2 ? window for 2-3 sec. and the window disappears again. Thats that - unfortunately.
What can be done?
Any help, every tip or hint is very welcome.
Thank you.
Ben
Re: KeePass2 on Raspberry Pi
Posted: Mon Jul 27, 2015 4:02 pm
by DerberMohikaner
Really no one ever experienced this or a similar problem?
No answer? No tip? No help?
Ben
Re: KeePass2 auf Raspberry Pi
Posted: Wed Jul 29, 2015 11:25 am
by itsmedoofer
From memory this is a know issue, try KeePassX.
Posted: Fri Jul 31, 2015 6:15 am
by DerberMohikaner
Thank you very much.
What exactly do you mean by "try KeePassX" ?
Thank you
Ben
Posted: Sun Sep 27, 2015 11:54 am
by _Annie_
Unfortunately, this is a problem for me, as well. I am using KeePass2 with its database on other devices syncing it via owncloud and KeePassX won't open the database as it's having a different structure (it only works for databases of version 1.x). And now?
Edit: Exporting to a database for KeePass 1.x did the job. But after updating to Jessie everything went fine with KeePass2. Then I moved to a RPi3 with Ubuntu Mate which works like a charm (without probs concerning KeePass 2).
Posted: Mon May 16, 2016 10:15 am
by dafloor
Hello everybody,
Although this thread is quite old, I would still like to present the solution I found to this problem :
http://stackoverflow.com/questions/3146 ... spberry-pi
It worked for me, so I'm a happy camper right now.
Just a few steps away from scrapping my PC and going Pi all the way.
Posted: Sat May 28, 2016 9:28 am
by chadw
dafloor wrote:Hello everybody,
So, you are using Raspbian Wheezy not Jessie ?
Posted: Sat May 28, 2016 12:31 pm
by scruss
KeePassX 2 now works with kdbx files. Dunno if it has hit the Raspbian repo yet, though.
