phmadeira
USB udev rules does it really work ?
Mon Jul 20, 2015 10:52 am
Hello
my usb port alway change on my pi 2
i have tried everything even add a powered usb hub to check
so here what i have tried
get the info with this:
sudo udevadm info --query=all --name=ttyUSB0
sudo lsusb -v | more udevadm info -a -n /dev/ttyUSB0
then keep the right info and make a news rule
sudo nano /etc/udev/rules.d/usb.rules
with for exemple :
i do have tried so much configuration that i an tired, must work only with few of then but nothing work
SUBSYSTEM=="tty",SUBSYSTEMS=="usb",ATTRS{serial}=="A9UX53JV",ATTRS{idProduct}=="6001",ATTRS{idVendor}=="0403",ENV{ID_VENDOR}=="FTDI",ENV{ID_MODEL}=="FT232R_USB_UART",ENV{ID_PATH}=="platform-bcm2708_usb-usb-0:1.3.3:1.0-port0",SYMLINK+="ttyUSB29"
SUBSYSTEM=="tty",ATTRS{serial}=="A9UX53JV",ATTRS{idProduct}=="6001",ATTRS{idVendor}=="0403",SYMLINK+="ttyUSB29"
SO Is somedoby did succes to make this hapend on his own pi , can you try before posting ?????
P: /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/ttyUSB0/tty/ttyUSB0
N: ttyUSB0
S: gps0
S: serial/by-id/usb-FTDI_FT232R_USB_UART_A9UX53JV-if00-port0
S: serial/by-path/platform-bcm2708_usb-usb-0:1.3.3:1.0-port0
S: ttyUSBsensor3
E: DEVLINKS=/dev/gps0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A9UX53JV-if00-port0 /dev/serial/by-path/platform-bcm2708_usb-usb-0:1.3.3:1.0-
port0 /dev/ttyUSBsensor3
E: DEVNAME=/dev/ttyUSB0
E: DEVPATH=/devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/ttyUSB0/tty/ttyUSB0
E: ID_BUS=usb
E: ID_MODEL=FT232R_USB_UART
E: ID_MODEL_ENC=FT232R\x20USB\x20UART
E: ID_MODEL_FROM_DATABASE=FT232 USB-Serial (UART) IC
E: ID_MODEL_ID=6001
E: ID_PATH=platform-bcm2708_usb-usb-0:1.3.3:1.0
E: ID_PATH_TAG=platform-bcm2708_usb-usb-0_1_3_3_1_0
E: ID_REVISION=0600
E: ID_SERIAL=FTDI_FT232R_USB_UART_A9UX53JV
E: ID_SERIAL_SHORT=A9UX53JV
E: ID_TYPE=generic
E: ID_USB_DRIVER=ftdi_sio
E: ID_USB_INTERFACES=:ffffff:
E: ID_USB_INTERFACE_NUM=00
E: ID_VENDOR=FTDI
E: ID_VENDOR_ENC=FTDI
E: ID_VENDOR_FROM_DATABASE=Future Technology Devices International, Ltd
E: ID_VENDOR_ID=0403
E: MAJOR=188
E: MINOR=0
E: SUBSYSTEM=tty
E: UDEV_LOG=3
E: USEC_INITIALIZED=13402105
thank you
topguy
Re: USB udev rules does it really work ?
Mon Jul 20, 2015 3:48 pm
I have made a few udev rules files and have some experience, especially with those tricky usb2serial. The clue is to keep the rules as simple as possible.
This is one I have used:
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{bcdDevice}=="0400", SYMLINK+="cradle0"
The only reason I use ATTRS{bcdDevice}=="0400" is I had another FTDI device of the same model and this was the only difference between the two. If you have only one of them then you should skip it.
You will also get a much better output for creating the rules if you try this command:
udevadm info -a -p /sys/bus/usb-serial/devices/ttyUSB0/
You will see that the output is divided into blocks (actuallly usb-driver layers ) and there is this not well known fact that you can't make a rule which contain elements from different blocks.
Finally two other important tools for debuggin udev rules:
# Reload rules after edit.
udevadm control --reload-rules
# Test the specific rules triggered for a device.
udevadm test -a add  $(udevadm info -q path -n /dev/ttyUSB0 )
The last one is the only one I have found that will tell you when you have made a syntax error in the rule-file.
