would this device work well with the rpi ?
http://www.dealextreme.com/p/aa-battery ... 48?item=12
Huh? Did you deliberately choose a difficult-to-solder part?Ed Raket wrote:Like.... this one from Farnell perhaps?![]()
http://nl.farnell.com/linear-technology ... dp/1783322
It does seem rather challengeing doesn't it... Lucky for us there's a 3-pin versionAndrewS wrote:Huh? Did you deliberately choose a difficult-to-solder part?Ed Raket wrote:Like.... this one from Farnell perhaps?![]()
http://nl.farnell.com/linear-technology ... dp/1783322LDOs are also available in 3-pin through-hole packages.
That looks beautiful, but no, probably not as it says 500mA output and the Pi needs 700mA at minimum to run reliably.jehan60188 wrote:what about this: http://www.ladyada.net/make/mintyboost/
