Internet over ETH/PPPoE
Posted: Sat Jun 20, 2015 2:01 pm
Hi everyone
I don't want to use access point but only my eth cable.
Internet provider has the list of MAC's and I changed my MAC in the PI with the following command:
And I changed the interface file
It works often but not always after reboot in the command line mode (not in the desktop mode).
Then I see my IP address and the ping command works.
But the following command doesn't works correctly. It builds the dependency tree with the success and also downloads few files
but next returns the "Failed to fetch" message because of some reasons. ( Size mismatch, No address associated with hostname)
When I start the desktop mode and turn on the WebBrowser the MAC address is changed. The previous MAC I seen in the command line before started the desktop mode in the ifconfig. After that the ping mode doesn't works.
I have PPPoE internet whit the login and password.
How can I use it on my PI with eth cable with my own changed MAC address.
How can i Iog in and make use of PPPoE internet connection on the PI?
sudo ifconfig eth0 down hw ether XX:XX:XX:XX:XX:XX Code: Select all
iface etho inet dhcp
hwaddress ether XX:XX:XX:XX:XX:XXIt works often but not always after reboot in the command line mode (not in the desktop mode).
sudo apt-get install motionI have PPPoE internet whit the login and password.
