I have bought and tested a Velleman VM205 oscilloscope + logic analyzer add-on card.
It works fine for what I need it for.
I also have an ADAFRUIT 2.8" touchscreen for my Raspberry PI
I've tested this too and it works fine once you setup the Graphic interface to send the screensignal to the TFT in the correct(ed) resolution.
Now I want to combine both SPI devices on the same SPI-bus.
How do I do this please ? The spec's for the VM205 kit are here:
http://www.velleman.eu ; search for: VM205
The intention is to make a full portable oscilloscope with these 2 .
The Velleman scope-kit only uses these pins : SPI_MOSI , SPI_MISO , SPI_SCLK , SPI_CE0 , GND , 3.3V , 5V
Many thanks for your help in advance !!! Ritchie
