The temps remain below 70c and i am using stock raspbian downloaded from raspberrypi.org, no modifications what so ever.
Using
watch -n 1 cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freqCode: Select all
watch -n 1 cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freqhi, if you start four process LxTerminals and issue the same command for cpu0, cpu1, cpu2,cpu3 then you will probably notice at least one of them will be running at 900 Mhz. (sometimes they all drop back to 600)ric96 wrote: . . .
UsingCode: Select all
rats. So, if you pin all four cores with something (compile, PI comp, whatever) all cores still show 600...?ric96 wrote:nope, still at 600mhz
Yeah, i did check all that...MarkHaysHarris777 wrote:rats. So, if you pin all four cores with something (compile, PI comp, whatever) all cores still show 600...?ric96 wrote:nope, still at 600mhz
Is the arm_freq set to 600 in the config.txt? This might just be a timing issue (I have noticed that I have to catch my cores at just the right time... mostly they are 600). But, if I keep checking they will bump to 900 even with normal operation let alone pinning the cores.
If I pin all four cores they all bump to 900... have you tried a reboot?
Psu is not the case, 2.1A sony powerful enough for an external hdd.MarkHaysHarris777 wrote:Well, maybe someone will chime in with some 'why' help. Got to thinking, how are you powering your PI? I don't know, but maybe the CPU steps down if it senses voltage drop? ... I mean, if not enough current is available from the supply (batt, or switching?) then maybe the CPU bumps down permanently until the power comes back up... have you tried a 2A power adapter?
rpdom@raspi5 ~ $ dpkg -l cpufrequtils
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii cpufrequtils 008-1 armhf utilities to deal with the cpufre
Thnkx so much, that solved it but why is the default cpu governor at power save??rpdom wrote:Can you check that you've got the cpufrequtils package installed? I just checked my Pi2 and I didn't have that installed and it said it was sitting at 600MHz all the time. I installed that package and it is now switching between 600 and 900 as needed.
If it doesn't show "ii" at the start of the line then it isn't installed.Code: Select all
rpdom@raspi5 ~ $ dpkg -l cpufrequtils Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==============-============-============-================================= ii cpufrequtils 008-1 armhf utilities to deal with the cpufre
I agree. Also, I don't have cpufrequtils installed either, but my system is not in power-save by default?ric96 wrote: Thnkx so much, that solved it but why is the default cpu governor at power save??
Makes no sense ...
did you download your raspbian before the 2015-05-05, if so then this might be an issue with the latest firmware...MarkHaysHarris777 wrote:I agree. Also, I don't have cpufrequtils installed either, but my system is not in power-save by default?ric96 wrote: Thnkx so much, that solved it but why is the default cpu governor at power save??
Makes no sense ...
Using cpufrequtils for now, will be looking forward to fixes...PhilE wrote:[ Copied from the spurious github thread ]
It's a Raspbian issue.
On a Pi 1, the default CPU frequencies are min=700, max=700. Therefore to make use of the ondemand or performance governor you have to overclock. If you use raspi-config to enable overclocking then it will also enable the raspi-config service (sudo service raspi-config start) which switches to the ondemand governor (unless Shift is held during boot).
On a Pi 2, the default frequencies are min=600, max=900, and it is possible to use ondemand without overclocking. So it makes sense to always start the raspi-config service on a Pi 2 (or to change the kernel default).
We're looking into the best way to resolve this.
sudo apt-get update
sudo apt-get upgrade
sudo rebootCode: Select all
root@raspberrypi # ping -f -c 1000 10.0.2.5 ; echo "hello world" ; cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
PING 10.0.2.5 (10.0.2.5) 56(84) bytes of data.
--- 10.0.2.5 ping statistics ---
1000 packets transmitted, 1000 received, 0% packet loss, time 443ms
rtt min/avg/max/mdev = 0.151/0.291/0.482/0.033 ms, ipg/ewma 0.444/0.296 ms
hello world
900000
Could be a recent issue with raspi-config because thats what gets updated an solves the problemsolar3000 wrote:I have a pi2 that hasn't been updated since I first got it in March.
I did a:before: 600MHzCode: Select all
root@raspberrypi # ping -f -c 1000 10.0.2.5 ; echo "hello world" ; cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq PING 10.0.2.5 (10.0.2.5) 56(84) bytes of data. --- 10.0.2.5 ping statistics --- 1000 packets transmitted, 1000 received, 0% packet loss, time 443ms rtt min/avg/max/mdev = 0.151/0.291/0.482/0.033 ms, ipg/ewma 0.444/0.296 ms hello world 900000
after: 900MHz
I also didn't instal any freq modules.
