Page 1 of 2
Raspberry Pi as a Wifi Pineapple
Posted: Sat Apr 11, 2015 1:31 am
by rpiswag
I know the code for the pineapple is on github and I want to make a diy version of the wifi pineapple. I saw a hackaday post http://hackaday.com/2013/04/29/wifi-pin ... e-attacks/ where someone turned a TP-Link TL-wr703n mini router into a diy wifi pineapple running by getting it to run open wrt. I know it is possible to run open wrt on a pi but can I turn the pi into a wifi pineapple? I know the router is only $25 on Amazon http://www.amazon.com/TP-Link-TL-WR703N ... 233&sr=1-4 but I want to make a pineapple clone even cheaper because I already have the materials to make it so I don't have to buy another piece of tech. I was also thinking about running fruity wifi on one of my model B+ and Kali Linux which I already have running on my pi 2.
Re: Raspberry Pi as a Wifi Pineapple
Posted: Sat Apr 11, 2015 4:52 am
by Jednorozec
Posted: Sat Apr 11, 2015 8:45 am
by davidcoton
rpiswag wrote: can I turn the pi into a wifi pineapple?
I don't know. Try it, then tell us how you got on. Use Google. If you get stuck at particular points, post here what you want to achieve, what you tried, and what actually happened.
Posted: Sat Apr 11, 2015 1:27 pm
by rpiswag
Thank you but before I do that I would like to know if I should buy the TP-LINK TL-WR702N for $18 or should I use my pi and run fruity wifi on it? I have an alpha networks awus036h usb wifi adapter but does fruity wifi support that model because it uses a realtek chip set and fruity wifi on there website says that fruity wifi supports realtek chip sets?
Posted: Sat Apr 11, 2015 1:57 pm
by ame
rpiswag wrote:Thank you but before I do that I would like to know if I should buy the TP-LINK TL-WR702N for $18 or should I use my pi and run fruity wifi on it? I have an alpha networks awus036h usb wifi adapter but does fruity wifi support that model because it uses a realtek chip set and fruity wifi on there website says that fruity wifi supports realtek chip sets?
I think you should use your Pi and run fruity WiFi on it.
Posted: Sat Apr 11, 2015 2:06 pm
by Heater
Why do you want to do this?
I have a TP-LINK TL-WR702N with OpenWRT running on it. Great little device. I use it to program Parallax Propeller chips remotely. Also works very well as a WIFI router.
Posted: Sat Apr 11, 2015 2:56 pm
by rpiswag
Thank you for your help but can you post a link of supported wifi adapters that fruity wifi supports? Do yo think $18 or about 17 Euros is a good price for the TP-LINK TL-WR702N?
Posted: Sat Apr 11, 2015 3:08 pm
by Heater
That sounds like a very reasonable price.
Posted: Sat Apr 11, 2015 3:28 pm
by rpiswag
Thank you and now back to one of my other questions. Can You post a link to a list of supported wifi adapters that fruity wifi supports?
Posted: Sat Apr 11, 2015 3:45 pm
by Heater
No.
Why don't you ask the developers? Or just try it?
Posted: Sat Apr 11, 2015 4:22 pm
by rpiswag
Where do I contact the developers?
Posted: Sat Apr 11, 2015 4:43 pm
by kusti8
rpiswag wrote:Where do I contact the developers?
On their forum? :roll:
Posted: Sat Apr 11, 2015 4:47 pm
by Heater
Their code is on github according to their download link.
That at least has an issue tacking system you can post questions to. Which will annoy them as that is not what an issue system is for. But hey, if they have no other means of communication what can they expect?
Posted: Sat Apr 11, 2015 5:25 pm
by rpiswag
I just pmed xtr4nge with some questions about Fruity Wifi. I think that person has the answers I am looking for.
Posted: Sat Apr 11, 2015 7:30 pm
by xtr4nge
Hi rpiswag,
I just replied to your PM. FruityWifi can be installed in a Raspberry Pi (or any other device/system) based on Debian like Raspbian. Also on Kali linux can be installed using apt-get as FruityWifi is now part of Kali repositories. With FruityWifi you will have what you are looking for (post topic).
You can use any wireless card supported by Hostapd (like Atheros chipsets) to get all the functionalities on FruityWifi. If the card is not supported (like Realtek chipsets) you can use the [AP] mode Airmon-ng but you will lose some functionalities like Karma and/or Mana.
For more details please check FruityWifi GitHub issues and wiki.
http://www.fruitywifi.com/index_eng.html
https://github.com/xtr4nge/FruityWifi/
regards
Posted: Sat Apr 11, 2015 10:39 pm
by rpiswag
What wifi adapter would you recommend that works with fruity wifi that is under $20. The wifi adapter would have to work with every module in fruity wifi. Preferably one I could buy from Amazon.com
Posted: Sat Apr 11, 2015 11:46 pm
by ame
rpiswag wrote:What wifi adapter would you recommend that works with fruity wifi that is under $20. The wifi adapter would have to work with every module in fruity wifi. Preferably one I could buy from Amazon.com
I think you should buy an alpha networks awus036h.
Posted: Sun Apr 12, 2015 12:00 am
by rpiswag
The alpha networks awus036h wifi adapter don't support all the modules in fruity wifi and I am looking for a network card that does. A card that uses and atheros chipset is the one that I am looking for and the alpha networks awus036h wifi card does not it uses a realtek chipset.
Posted: Sun Apr 12, 2015 12:24 am
by ame
rpiswag wrote:The alpha networks awus036h wifi adapter don't support all the modules in fruity wifi and I am looking for a network card that does. A card that uses and atheros chipset is the one that I am looking for and the alpha networks awus036h wifi card does not it uses a realtek chipset.
Oh. But I read on the internet that fruity wifi, on their website, says that fruity wifi supports realtek chip sets.
Posted: Sun Apr 12, 2015 12:40 am
by rpiswag
Yes it does (kind of). Fruity Wifi will run in a Realtek chip set but not all of the modules work and fruity wifi can only work in ap mode. That is why I want to use a Atheros chip set because it can use all of the features that fruity wifi has to offer. Here is a quote from another post in this thread relating to what I just mentioned
Posted: Sun Apr 12, 2015 12:44 am
by ame
rpiswag wrote:Yes it does (kind of). Fruity Wifi will run in a Realtek chip set but not all of the modules work and fruity wifi can only work in ap mode. That is why I want to use a Atheros chip set because it can use all of the features that fruity wifi has to offer. Here is a quote from another post in this thread relating to what I just mentioned
Ok, well I think you should buy a wifi card with an Atheros chipset.
Posted: Sun Apr 12, 2015 1:29 am
by rpiswag
Do you know of a specific model you would recommend?
Posted: Sun Apr 12, 2015 1:46 am
by ame
rpiswag wrote:Do you know of a specific model you would recommend?
No. Sorry. You could probably find one on Amazon.
Posted: Sun Apr 12, 2015 11:28 am
by rpiswag
Thats ok! I was thinking about getting the alpha awus036hna. Here is a link http://www.amazon.com/Alfa-AWUS036NHA-W ... awus036nha. Will this wifi adapter work with all of the modules that Fruity Wifi supports?
Posted: Sun Apr 12, 2015 12:54 pm
by ame
rpiswag wrote:Thats ok! I was thinking about getting the alpha awus036hna. Here is a link http://www.amazon.com/Alfa-AWUS036NHA-W ... awus036nha. Will this wifi adapter work with all of the modules that Fruity Wifi supports?
I don't know. I heard you can use any wireless card supported by Hostapd (like Atheros chipsets) to get all the functionalities on FruityWifi.
You could buy it and test it yourself, and report your findings to this group, and maybe the FruityWifi group. If no-one else has done it, or written about it then you will be the first and I am sure it will be appreciated (even if it doesn't work that's still good a good data point).
