Forgotten01
Pi 2b solder points for direct power
Fri Apr 10, 2015 4:11 pm
Hello all, I want to power my pi without using a micro usb cable, do I still solder ground to pp1 and 5v to pp3? That is how I have it soldered on my B+
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
Scott Adams
klricks
Re: Pi 2b solder points for direct power
Sat Apr 11, 2015 4:49 am
Forgotten01 wrote:Hello all, I want to power my pi without using a micro usb cable, do I still solder ground to pp1 and 5v to pp3? That is how I have it soldered on my B+
I think you have it backwards.... at least how you typed it... If wired like that you would be smoking something......
B+ is the same as 2B
PP1 & PP2 & F1 (Side closest to edge of board) are +5V from the micro USB power supply.
PP3 is ground but I would use one of the more robust solder connections at any of the port shields - HDMI, USB etc.
Forgotten01
Sat Apr 11, 2015 5:40 pm
oh, okay...... the cable I have connected is just black, I have long forgotten which one was which XD
Scott Adams
