dpenezic
TL-WN823N kernel driver issue - eth0 stop working
Tue Mar 24, 2015 10:32 pm
i discover some issue in connection with TP-LINK TL-WN323N USB wireless dongle and last raspbian image (2015-02-16).
Basically eth0 stop working , and only reboot help.
I found in kernel.log follow :
# normal working state
Mar 19 16:22:10 raspberrypi kernel: [17855.327854] rtw_wx_set_mlme
Mar 19 16:22:10 raspberrypi kernel: [17855.327897] rtw_wx_set_mlme, cmd=1, reason=3
Mar 19 16:22:27 raspberrypi kernel: [17872.982935] rtw_wx_set_mlme
Mar 19 16:22:27 raspberrypi kernel: [17872.982979] rtw_wx_set_mlme, cmd=0, reason=1
Mar 19 16:32:09 raspberrypi kernel: [18455.033306] rtw_wx_set_mlme
Mar 19 16:32:09 raspberrypi kernel: [18455.033348] rtw_wx_set_mlme, cmd=1, reason=3
Mar 19 16:33:47 raspberrypi kernel: [18552.382564] rtw_wx_set_mlme
Mar 19 16:33:47 raspberrypi kernel: [18552.382608] rtw_wx_set_mlme, cmd=0, reason=1
#issue occur
Mar 19 16:40:29 raspberrypi kernel: [18954.877045] rtw_cmd_thread: DriverStopped(0) SurpriseRemoved(1) break at line 482
#eth0 stop working
Mar 19 16:40:29 raspberrypi kernel: [18955.090706] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -32
Mar 19 16:40:29 raspberrypi kernel: [18955.090745] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
Mar 19 16:40:29 raspberrypi kernel: [18955.090765] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
#finally multiple line
Mar 19 16:40:39 raspberrypi kernel: [18964.719280] smsc95xx 1-1.1:1.0 eth0: Failed t
o write reg index 0x00000014: -32
Mar 19 16:40:40 raspberrypi kernel: [18965.720906] smsc95xx 1-1.1:1.0 eth0: Failed t
Mar 19 16:40:41 raspberrypi kernel: [18966.722363] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -32
Mar 19 16:40:42 raspberrypi kernel: [18967.723925] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -32
Mar 19 16:40:43 raspberrypi kernel: [18968.725401] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -32
Mar 19 16:40:44 raspberrypi kernel: [18969.726953] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -32
also when i change dongle with other one everything work normally.
Technical information about wireless dongle:
pi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
pi@raspberrypi ~ $ sudo lsusb -vv -s 004
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0x8178 RTL8192CU 802.11n WLAN Adapter
  bcdDevice            2.00
  iManufacturer           1 802.11n
  iProduct                2 USB WLAN
  iSerial                 3 00e04c000001
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           46
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           4
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
pi@raspberrypi ~ $ sudo lsusb -t
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/5p, 480M
        |__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
        |__ Port 4: Dev 4, If 0, Class=vend., Driver=rtl8192cu, 480M
pi@raspberrypi ~ $ sudo modinfo 8192cu
filename:       /lib/modules/3.12.35+/kernel/drivers/net/wireless/rtl8192cu/8192cu.ko
version:        v4.0.2_9000.20130911
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     92ABD77EE49D06D8157B4F8
alias:          usb:v0BDAp8186d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0789p016Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p0070d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04BBp0950d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v06F8pE035d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p0100d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp2E2Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v050Dp1004d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E66p0020d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E66p0019d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0846pF001d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0846p9021d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17ABd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p0061d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v20F4p624Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v050Dp2103d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v050Dp2102d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v4855p0091d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v07AAp0056d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v07B8p8178d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pAB2Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392p7822d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0586p341Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p330Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3309d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p330Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3307d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019p1201d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04F2pAFFCd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04F2pAFFBd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04F2pAFF8d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04F2pAFFAd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04F2pAFF9d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04F2pAFF7d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3358d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3359d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp317Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp0A8Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:vCDABp8011d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04BBp094Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp1E1Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17BAd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:vCDABp8010d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p330Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pAB2Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019p4902d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0846p9041d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v4856p0091d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp5088d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p005Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3357d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v4855p0090d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v20F4p648Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pAB2Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v050Dp1102d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3308d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v103Cp1629d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v06F8pE033d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0EB0p9071d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v07B8p8189d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392p7811d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p0052d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pED17d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v1058p0631d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8191d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp817Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8178d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8177d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp17C0d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp018Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp818Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp817Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8754d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp817Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp817Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp817Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp817Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8170d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8176d*dc*dsc*dp*ic*isc*ip*in*
depends:
intree:         Y
vermagic:       3.12.35+ preempt mod_unload modversions ARMv6
parm:           rtw_ips_mode:The default IPS mode (int)
parm:           ifname:The default name to allocate for first interface (charp)
parm:           if2name:The default name to allocate for second interface (charp)
parm:           rtw_initmac:charp
parm:           rtw_channel_plan:int
parm:           rtw_chip_version:int
parm:           rtw_rfintfs:int
parm:           rtw_lbkmode:int
parm:           rtw_network_mode:int
parm:           rtw_channel:int
parm:           rtw_mp_mode:int
parm:           rtw_wmm_enable:int
parm:           rtw_vrtl_carrier_sense:int
parm:           rtw_vcs_type:int
parm:           rtw_busy_thresh:int
parm:           rtw_ht_enable:int
parm:           rtw_cbw40_enable:int
parm:           rtw_ampdu_enable:int
parm:           rtw_rx_stbc:int
parm:           rtw_ampdu_amsdu:int
parm:           rtw_lowrate_two_xmit:int
parm:           rtw_rf_config:int
parm:           rtw_power_mgnt:int
parm:           rtw_low_power:int
parm:           rtw_wifi_spec:int
parm:           rtw_special_rf_path:int
parm:           rtw_antdiv_cfg:int
parm:           rtw_enusbss:int
parm:           rtw_hwpdn_mode:int
parm:           rtw_hwpwrp_detect:int
parm:           rtw_hw_wps_pbc:int
parm:           rtw_max_roaming_times:The max roaming times to try (uint)
parm:           rtw_force_iol:Force to enable IOL (bool)
parm:           rtw_mc2u_disable:int
parm:           rtw_mac_phy_mode:int
parm:           rtw_80211d:int
parm:           rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
Any idea how to fix issue ?
Regards,
Dubravko
