Is the RPi2 the right Tool for the Job?
Posted: Sun Mar 22, 2015 10:21 pm
Hi there, my name is Rachel and i'am at the moment searching for a tool (not necessarily a Rpi) that would do the following Job as convenient and rock-solid as can be.
I will be traveling for a few months in Africa and in the meanwhile i want to have a constant videofeed of my home in the time being.
Here's the Plan:
A 'Microcomputer' in a Waterproof Inclosure equipped with a small 6000mah-Lipo-UPS sits on top of my House on a Pole equipped with a servo-motor that does a 360°-Pan while it captures a 1080p-Video which gets saved in "Directory-X".
A few minutes later a script gets run and encrypts the video-files using "gpgdir"* (https://cipherdyne.org/gpgdir/) and deletes the original video-files leaving only the encrypted ones in the folder.
Than "grive" (http://www.lbreda.com/grive/start) comes into play and syncs the files in the directory to my Google-Drive.
And i'll watch them later a few thousand miles away on my Notebook.
So far so good, but is the Pi2 a good option?
At the moment i own a Pi B Rev2 and an Odroid-W(awesome Board which isn't produced anymore due to an asshat move imo, but a whole another story).
The first one is basically awful in every way possible (power-hungry, high-heat, data-corruption on SD and SLOW AS HELL), the second one fixes most of the problems and has a great emmc-support and therefore no data-corruption and high data-throughput but lacks the Ethernet-Port and would depend on a wireless connection (no problem actually) but is at the end of the day, although better in almost any way thinkable still as slow as your regular PI-B when it comes to encryption.
So what are the candidates to replace them for this (and only this) task?
Odroid C-1 (Quadcore with higher clock-speed than the Pi, no need of silly licenses but probably worse gpu-drivers which could lead to worse performance, but overall possibly the better option for this task???)
RPI-2B (Quadcore with overall slower Clockspeed, way worse I/O-Speed but probably better drivers and hopefully without data-corruption-issues as all the previous Pi's)
BananaPi (propably the least viable option, but i might be wrong?)
I really wish for an honest non-fanboyish answer to this problem, or in short a recommendation for the best-fit mini-computer for this task.
(As honest as somebody that would never recommend a NAS-based Pi due to it's (still) faulty USB/ETH-Design
P.S. i would most-likely use the 5MPx-Picam.
Sincerely, Rachel.
Here's the Plan:
Sincerely, Rachel.
