edmundodantes1
Noise or interference in analog output
Fri Mar 13, 2015 12:56 pm
Hello.
I've had a Raspberry Pi 2 for a few days. It is connected to the TV with HDMI, but I want to use audio system in analog output. I configure audio in OpenELEC in analog mode. But, when I play music or watch a video, there is a quite annoying background noise, as interference, which only attenuates if I turn the volume up.
It isn't a speaker problem because I've got the same problem with the headphones. The noise or interference it's only heard when the speakers are emitting a sound. In fact, the sound of the menu also has interference. The HDMI sound is fine , but I'm interested in analog output.
I've been looking for a solution for a couple or days, but I haven't found a solution. I've even tried to install a ferrite filter in the power cord , but it hasn't worked.
Have you got any idea of which could be the problem? Thank you very much
Tosselino
Re: Noise or interference in analog output
Wed Mar 18, 2015 9:44 am
I have the exact same issue. But no solution. Have you tryed any other SW? I think this is related to the actual HW, but would be interesting to check any other SW/OS.
yv1hx
Mon Mar 23, 2015 8:00 pm
edmundodantes1 wrote:Hello.
Main AC hum maybe? http://en.wikipedia.org/wiki/Mains_hum
Marco-Luis
Telecom Specialist (Now Available for Hire!)
http://www.meteoven.org
http://yv1hx.ddns.net
http://twitter.com/yv1hx
Tosselino
Tue Mar 24, 2015 8:04 am
In my case I think it was a grounding issue. When I connected the 3.5 mm analog output of the RPi to a stereo amplifier (using RCA) instead of using headphones the strange noise was gone.
yv1hx
Tue Mar 24, 2015 2:11 pm
Tosselino wrote:In my case I think it was a grounding issue. When I connected the 3.5 mm analog output of the RPi to a stereo amplifier (using RCA) instead of using headphones the strange noise was gone.
How are you powering your RasberryPi?
Marco-Luis
