Trying compile and install Apache from source. [RESOLVED]
Posted: Mon Mar 02, 2015 11:15 am
by sim_tcr
I am trying compile and install Apache from source (2.4.12). I am trying to install to /Splunk dir as user splunk.
[splunk@xxxxxxxxxxxxx /]$ ls -la | grep Splunk
drwxrwxr-x    5 splunk splunk     9 Mar  2 06:04 Splunk
I downloaded httpd-2.4.12.tar.gz and extracted the package to /Splunk/httpd-2.4.12
I downloaded apr-1.5.1.tar.gz & apr-util-1.5.4.tar.gz and extracted the contents to /Splunk/httpd-2.4.12/srsclib/apr and /Splunk/httpd-2.4.12/srsclib/apr-util respectively.
From /Splunk/httpd-2.4.12 I ran ./configure --with-included-apr --prefix=/Splunk/apache and it completed without errors.
From /Splunk/httpd-2.4.12 I ran make and it completed without errors.
From /Splunk/httpd-2.4.12 I am running make install and it ends with errors.
make[2]: Leaving directory `/Splunk/httpd-2.4.12/support'
cp: preserving permissions for `/Splunk/apache/modules/httpd.exp': Operation not supported
make[1]: *** [install] Error 1
make[1]: Leaving directory `/Splunk/httpd-2.4.12/support'
make: *** [install-recursive] Error 1
Can any one help please?
Re: Trying compile and install Apache from source.
Posted: Mon Mar 02, 2015 11:46 am
by Heater
You don't have permissions to do that. Try using:
$ sudo make install
Posted: Mon Mar 02, 2015 11:53 am
by sim_tcr
Heater wrote:You don't have permissions to do that. Try using:
$ sudo make install
I do not have sudo permission. Only reason I want to install to /Splunk is because I do not have sudo permission.
Posted: Mon Mar 02, 2015 12:01 pm
by Heater
Google is your friend. You will find "steps of how I installed apache-httpd on a non-root user" here:
http://stackoverflow.com/questions/9436 ... stallation
Not written by me, I have no idea how well that works.
Edit:
Wait a minute. If you cannot get root permissions how did you create the /Splunk directory ?
If that directory already existed presumably you don't have enough permissions to access it.
The answer is to install it to some place you do have permission to use. Hence the
--prefix=/home/username/apache/httpd-2.4.2/ option in the instructions in the link above.
Posted: Fri Mar 06, 2015 11:38 am
by sim_tcr
Heater wrote: Wait a minute. If you cannot get root permissions how did you create the /Splunk directory ?
/Splunk was created by admins and gave splunk id and group as owner and group. I (splunk) do have full permissions to /Splunk see below,
So I had tried --prefix=/Splunk/apache
I am still stuck with the original error I posted first post.
Posted: Sun Mar 08, 2015 6:49 am
by sim_tcr
Here is an update. I tried compiling Apache on my raspberry pi 2 by following the exact same steps and it was successful. Differences are,
on pi I ran it as user 'pi' where on other machine I ran it as "splunk"
on pi I set '--prefix=/home/pi/apache' where on other machine '--prefix=/Splunk/apache'
I checked permission on /home/pi and /Splunk,
pi@raspiabita /home $ ls -la | grep pi
drwxr-xr-x 21 pi   pi   4096 Mar  8 12:06 pi
on raspberry pi, pi user has full access to /home/pi and on other machine splunk user has full access to /Splunk.
I am still trying to figure out why make install command on other machine fails with,
Re: Trying compile and install Apache from source. [RESOLVED
Posted: Sun Mar 08, 2015 11:29 am
by sim_tcr
I resolved my issue by downloading the source to my home directory (/home/splunk/) and then compiling.
Earlier it was at /Splunk.
