RaspberryPi2 - Dead after two weeks (mostly) idle
Posted: Mon Mar 02, 2015 7:56 am
by forenbenutzer
This weekend my RaspberryPi2 died. I used the latest Raspbian image from the official web page and let it run for almost two weeks without any load (except an OpenVPN client).
Maybe I simply got a "Monday's product", as we say here in Germany.
My question is: Does anyone of the new Pi2 owners also have this issue?
Some first experience reports about its stability?
Thank you all for the replies.
(Additional question: I already bought a MPG2 key for the broken raspberry. My money is gone, am I right?)
Re: RaspberryPi2 - Dead after two weeks (mostly) idle
Posted: Mon Mar 02, 2015 8:40 am
by jamesh
If a new SD card doesn't fix the problem, then return for a warrantee replacement. AFAIK, there haven't been any other reports like this, but given the number sold I would expect some failures in the field for faults that cannot be detected by the production line.
Not sure about the MPEG key.
Posted: Mon Mar 02, 2015 8:44 am
by gkreidl
What do you mean by "died"?
Do you see anything on the monitor screen if it starts to boot? Did you try another SD card or power supply?
by forenbenutzer
Thank you for the reply. No, a new SD card does not fix the problem. The Pi also gets really hot without any SD card inserted. That should not be normal I think?
Edit: Thank you for the advice. This is my 15th (?) raspberry, so the typical causes for failures can be excluded.
Posted: Mon Mar 02, 2015 8:57 am
by RaTTuS
really hot usually means it has been shorted ! - is it in a case
Posted: Mon Mar 02, 2015 9:02 am
by jamesh
I'm suspecting a bad solder joint somewhere that was OK when manufactured but has since failed in long term use.
Posted: Mon Mar 02, 2015 9:05 am
by forenbenutzer
Yes, it has been in the same case at the same place like a B for over a year whithout shutdown and without any issues. Also, no overclocking has been done so far. The case has lots of holes for providing enough air flow.
Posted: Mon Mar 02, 2015 10:23 am
by mikerr
Interesting - here in the UK we call those "Friday afternoon products"
http://www.phrases.org.uk/meanings/143350.html
Posted: Mon Mar 02, 2015 10:30 am
by jamesh
I'm not entirely sure that almost fully automated productions lines have that sort of a problem...!! Those pick and place machines though, can be a bit...picky....
Posted: Mon Mar 02, 2015 10:31 am
by Adrian_Day
My RaspberryPi 2 looks to have an intermittent fault on the USB bus - USB devices aren't always registered on boot or insertion, when registered they also randomly drop out and reappear. Same goes for the ethernet port (discovered when attempting to trace the problem. I generally use a wifi dongle).
Ordered it the day after it was announced. Noticed there was a problem a few days after receiving it when network shares kept disappearing. Have swapped the SD card, wi-fi dongle, power supply, checked routers, etc.. Contacted the supplier and am currently waiting for them to confirm I can return it for replacement.
This is my fourth Pi and the first I've experienced a problem with. Given the number sold, I guess it's only reasonable to expect a few duds that sneak through quality control.
-- Adrian
Posted: Mon Mar 02, 2015 10:36 am
by forenbenutzer
Well, the weekend starts at friday afternoon and ends at monday... afternoon. Sounds valid to me.
Nevertheless, I still am looking for an answer to my MPG2 licence key question.
Posted: Mon Mar 02, 2015 10:44 am
by RaTTuS
you will have to email the foundation for that info [re mpeg licence]
Posted: Mon Mar 02, 2015 10:46 am
by forenbenutzer
Thank you for that information. Hopefully other people won't suffer from broken Pi2s.
Posted: Mon Mar 02, 2015 10:50 am
by RaTTuS
go though the returns procedure to get a new one
