mmkw43
ARMv7+ ?
Mon Feb 23, 2015 5:51 pm
Trying to install pycharm on a PI with Raspian and get this error "server vm is only supported on armv7+"
?? -- thanks for any help
In terminal I just put in the path to pycharm.sh
Re: ARMv7+ ?
Mon Feb 23, 2015 6:10 pm
mmkw43 wrote:Trying to install pycharm on a PI with Raspian and get this error "server vm is only supported on armv7+"
Model of Raspberry Pi :?:
Re: ARMv7+ ?
Mon Feb 23, 2015 6:18 pm
Which model Pi? Only the Pi 2 has an ARMv7. All the others have ARMv6.
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 6:20 pm
all I can see is a 2011.12 on the pcb itself -- can I see hardware info in raspian?
Bruny
Re: ARMv7+ ?
Mon Feb 23, 2015 6:23 pm
rpdom wrote:Which model Pi? Only the Pi 2 has an ARMv7. All the others have ARMv6.
and Raspian is still on 6?
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 6:30 pm
lx panel 0 7 .1 is all I see when I try "about" info -- where do i see the raspbian version?
B.Goode
Re: ARMv7+ ?
Mon Feb 23, 2015 6:39 pm
As previously discussed -
Download: http://download.jetbrains.com/python/py ... 0.4.tar.gz
Unpack it using these instructions: https://www.jetbrains.com/pycharm/downl ... p?os=linux
That works for me on an RPi Model 2 B running the mid-Feb 2015 version of Raspbian.
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 6:41 pm
I have.
All you do is point to the pycharm.sh file in terminal after unpacking right? I do and then get that error.
Re: ARMv7+ ?
Mon Feb 23, 2015 6:42 pm
Raspbian was specifically built for v6 (and above).
You can find which CPU you have using a terminal
rpdom@raspi:~$ grep model /proc/cpuinfo
model name	: ARMv6-compatible processor rev 7 (v6l)
That shows I have an ARMv6 CPU on my Pi, which is a model B ver 1.0.
On Pi 2B you will get something like
model name : ARMv7 Processor rev 5 (v7l)
(as there are four ARMv7 CPU cores on the Pi2)
mmkw43
Re: ARMv7+ ?
How do I get the raspian version -- don't see an "about" or anything
ghans
Re: ARMv7+ ?
Mon Feb 23, 2015 6:45 pm
lsb_release -a
also interesting :
cat /boot/issue.txt
ghans
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 6:48 pm
It says arm v6 compatable rev7 (v6l)
ghans
Re: ARMv7+ ?
Mon Feb 23, 2015 6:50 pm
Well , there you have it. PyCharm will simply not run on your "old" model B1 or B+1 .
ghans
B.Goode
Re: ARMv7+ ?
Mon Feb 23, 2015 6:54 pm
Confirmed.
If I try the same download/unpack/execute steps on an 'original' RPi Model B I get:
pi@raspberrypi ~ $ ./pycharm-community-4.0.4/bin/pycharm.sh
Error occurred during initialization of VM
Server VM is only supported on ARMv7+ VFP
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 7:30 pm
Ok -- sorry guys -- guess I must have bought this is older than I thought. Think it must be the one I bought where I said "gotta get one of those" and it sat in my shop.
Oh well -- my aplogies. I'll have to see what the model1's capabilities are and use it for that.
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 7:37 pm
Hey -- who has the new PI2 in stock in the US -- are they available?
mmkw43
Re: ARMv7+ ?
Mon Feb 23, 2015 7:58 pm
nevermind -- mcm just bought one
